Calculate the maximum height that m1 and m2 rise after collision?
The problem involves a frictionless track with a quarter-circle path where block m1 collides elastically with block m2, which is initially at rest. The goal is to calculate the maximum height that both blocks rise to after the collision, given specific masses and the radius of the quarter circles.
  • Participants discuss finding the speed of m1 after it falls through the quarter-circle before the collision. There is a focus on applying conservation of momentum for the collision and questions about how to calculate the velocity of m1.
Some participants have suggested methods to determine the speed of m1 after falling, including using energy principles or forces. There is an ongoing exploration of the initial conditions and how they relate to the subsequent calculations.
Participants are considering the implications of the frictionless environment and the elastic nature of the collision, as well as the initial height of m1 above the horizontal section.
kalisious
Consider a frictionless track. Imagine point A to B is one quarter of a circle; point B to C is a horizontal flat plane; point C to D is also one quarter of a circle.
The block m1 is released from A. It makes a head-on elastic collision at B with m2 (that is initially at rest) Calculate the maximum height to which m1 and m2 rise after collision.
m1 = 2kg
m2 = 10 kg
radius of quarter circles = 4.9 m
p=mv
m1vf + m2vi = (m1 + m2)v
y=1/2 at^2
I am not quite sure how to attempt a solution.
Can you find out how fast m1 is going after it falls through the quarter of a circle A to B? Then you could do conservation of momentum on the collision at B.
I understand the equation for conservation of momentum, but how do I go about finding the velocity as you mentioned?
Draw the diagram. You should see how high above the BC horizontal section m1 is initially. From the initial height, you can calculate its speed after falling through the height either by using forces or energies.
  • · Replies 22 ·
