Calculate the Sound intensity level
To calculate the sound intensity levels from a jackhammer with a power of 10 W at distances of 2.0 m and 50.0 m, the intensity (I) must first be determined using the formula I = P / A, where A is the surface area of a sphere. The sound intensity level in decibels (dB) can then be calculated using the equation β = (10 dB) log (I/Io), with Io being 1.0 x 10^-12 W/m^2. There is some discussion about whether to use the surface area of a sphere or hemisphere for the calculations. Accurate calculations will depend on correctly applying these formulas and understanding the assumptions regarding the sound source.
ninaw21
A jackhammer with a sound power of 10 W is operating in the countryside. Calculate the
intensity levels at distances of 2.0 m and 50.0 m from the jackhammer. Calculate the
corresponding levels in dB.
β = (10dB) log (I/Io)
where, β = sound intensity level, I = intensity, Io= 1.0x10^-12 W/m^2
I honestly have no idea how to do this question! Please help
Welcome to PF.
If you inspect your formula, you will notice that you need to find I. The definition of I is power per unit area: I = P / A.
Assume the jackjammer is a point source. Then A will be the surface area of a sphere. You are given the power.
Try this and show your work !
Welcome to the PF.
It looks like the units of sound intensity are W/m^2:
http://en.wikipedia.org/wiki/Sound_intensity
So you would want to calculate the surface area that the 10W is going through at those distances away from the source, and use that surface area and the 10W number to figure out the sound intensity at those distances.
One question would be should you use a sphere's area or hemisphere's area for your surface that the sound is going through. I'm not sure which this problem assumes. I know which one I'd use based on the wording, but I don't know if it would be the same as the problem wants...
EDIT -- Edged out by edgepflow! :smile:
Thanks guys!
