Calculate Turbine gross and net output
The discussion revolves around calculating the turbine gross and net output of a steam power plant, along with its thermal efficiency and maximum possible efficiency. The heat added to the boiler is 2.9 million kJ, and the heat rejected in the condenser is 2.1 million kJ, with pump work specified as 250,000 kJ. The gross work output is determined to be 800 MJ, while the net output, after accounting for pump work, is 550 MJ. The thermal efficiency is calculated as 19%, and the maximum possible efficiency, based on Carnot's theorem, is 53%. The calculations and understanding of the concepts were clarified throughout the discussion.
Nemo's
A steam power plant consists of a boiler, a turbine, a condenser and a pump. The temperature of the inner walls of the boiler is 350oC and the temperature of the condenser cooling water is 20oC. During a certain interval of time, the heat added to the boiler is 2.9x106 kJ and the heat rejected in the condenser is 2.1x106 kJ. If the pump work is 250000 kJ, estimate : a. The turbine gross and net output. b. The thermal efficiency of the power plant. c. The maximum possible efficiency of the power plant.
[/B]
Second law of thermodynamics.
Applying law of conservation of energy to get Wout (Turbine work)
Win-Wout+Qh-Ql=0
250M-Wout+2.9G-2.1G=0
Wout=250.8 MJ
[/B]
Win-Wout+Qh-Ql=0
Wout=250.8 MJ
What's the gross output of the turbine? The net output? What about parts b) and c)?
I actually don't understand the difference between the net and gross outputs.
a)I need to make sure that it's correct to get the turbine work output using the law of conservation of energy so I can proceed to b.
b) If I get the turbine output power from a then the efficiency=total power input/total power output =Wout/250M
c)Maximum efficiency =1-TL/TH =1- ((20+273)/(350+273))=0.53=53%
Please correct me if I am wrong.
The turbine is the only thing between the boiler and the condenser. What does that tell you about the gross work output?
The pump is between the condenser and the boiler. Part of the gross output of the turbine must be used to drive the pump. Net work output is ...?
I think that makes the gross work output = turbine work output = 250.8M and the net output =turbine work output - pump work = 0.8M (according to my previous calculations).
Your original calculation 1) doesn't make sense and 2) is arithmetically incorrect
Win-Wout+Qh-Ql=0
Wout=250.8 MJ
2.9 G - 2.1 G = 800 M joules
250 M + 800 M = 1050 M joules - Wout = 0
So, how did you come up with Wout = 250.8 M joules? None of your original numbers even have that degree of precision.
SteamKing said:
Your original calculation 1) doesn't make sense and 2) is arithmetically incorrect2.9 G - 2.1 G = 800 M joules
Yes I made an arithmetic mistake. Wout should be 1050M according to my original calculation. so net output 1050-250=800M
I think I know why my original calculation doesn't make sense. I should appply the first law of thermodynamics. However, I don't know the mass or the enthalpy.
No, this is still wrong, but it is arithmetically correct. Where does the 1050 come from?
You don't need to know either. You're given the total heat quantities, which is what you would have obtained from knowing the mass flow rates and the enthalpies anyway.
O.k what if I say turbine work output = Qh-Ql=2.9G-2.1G=800M would that be correct? I am not sure because similarly I was expecting pump work = 2.9G-2.1G to apply but it doesn't.
Gross or net output?
Why would you think that? The pump work is explicitly given as 250,000 kJ, or 250 MJ, in the problem statement.
2.9 GJ - 2.1 GJ ≠ 250 MJ
Gross=800M
Net=800m-250M=550M
This makes sense to me. I hope I got it right this time.
Nemo's said:
Gross=800M
Net=800m-250M=550M
Yes, that's much better.
b)thermal efficiency = Net Work /Qh = 550M/2.9G =19%
c) carnot efficiency = 53% (previusly calculated)
So is this the correct solution ?
Looks good to me.
Thank you so much for your help.
