Calculating Ascent Rate and Peak Altitude of a High Altitude Balloon
The discussion focuses on calculating the ascent rate and peak altitude of a helium-filled weather balloon. The ascent rate remains relatively stable with altitude, typically fluctuating by no more than 10% due to factors like wind and temperature. Peak altitudes for high-altitude balloons can reach between 30-37 km, with some hobbyists achieving up to 40 km. The user is interested in determining the ascent duration to their estimated peak altitude of 26 km and how long the balloon will remain above the tropopause. Accurate calculations are essential for planning successful high-altitude balloon flights.
thespaceman
Howdy,
I am looking to find the rate of ascent for a weather balloon filled with helium. My assumptions as of now are total payload weight=10lbs, total balloon weight=2lbs, total balloon volume(at launch)=150ft^3, balloon diameter(at launch)=6ft.
Also, how does the rate of ascent change with altitude?
And lastly, what is the peak altitude it will reach?
Any help will be greatly appreciated. :)
-thespaceman
Hey thespaceman,
I actually have some experience with weather balloons, so thought I'd post what I know. Give consideration that this is taken from practical experiments personally and not from literature.
Your first question about ascent change with regards to altitude. It should not change depending on altitude, because as the pressure gets less and less, the balloon is expanding, giving the same ratio of helium displacement over air. Of course, wind currents, and temperature fluctuations can offset your rate of ascent by a small amount, but nearly impossible to calculate. Some fluctuations will cause the rate of ascent to speed up, others will slow it down. On average the ascent rate should not fluctuate more than 10%.
As with your second question, the peak altitude really depends on the material of your weather balloon and where you get it from. High altitude weather balloons can go 30-37km in height, with some amateur hobbyists boasting of nearly 40km. Personally 33km was the highest I've ever gotten one, but I'm working on a budget of about $200 per flight (with many reusable parts).
Hopefully this helped, best of luck.
That is extremely helpful thank you. What I am trying to do now is to calculate the ascent rate that my balloon will have. I calculated an approximate peak altitude already to be 26km, but what I would like to calculate by hand is how long it will take to get there. What is really important is how long I will be above the tropopause.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
