Calculating Ball Velocity with Unit Vectors
  • Thread starter Thread starter UrbanXrisis
    Angle Ball
To calculate the ball's velocity when shot at 5.4 m/s at a 30-degree angle, the x-component is determined using 5.4cos(30) and the y-component with 5.4sin(30). The velocity vector can be expressed as V = (5.4cos(30))ex + (5.4sin(30))ey, where ex and ey are unit vectors in the x and y directions, respectively. For further calculations involving time, acceleration can be added to the y-component. To visualize the vector, sketch it at a 30-degree angle to the horizontal, with the x-component being 5.4cos(30) and the direction of motion relative to the x-axis also being 30 degrees.
UrbanXrisis
If a ball is shot out at 5.4m/s and makes an angle of 30 degrees with the horizontal, the x component would be 5.4cos30 and the y component would be 5.4sin30 correct?
The question then asks me to write an expression for the ball’s velocity, v, using unit vectors for the x-direction and the y-direction. Wouldn’t the velocity be just 5.4m/s? I don’t understand wht they are asking.
Unit vectors are a simple way of describing a 3d (or 2d) vector. Basically, you put everything that describes the x-direction together and put 'ex' with a vector sign over it behind it. Do thesame for the y-direction.
In this case: the x-component of the speed is just 5.4cos(30), so that part of the vector is (5.4cos(30))*ex (actually make that x subscript and add an arrow above the e)
The y-component is thesame thing, only with 5.4sin(30) and ey. In case they ask you to do the expression for t, you'll have to add acceleration like this:
V = (5.4cos(30))*ex + (5.4sin(30) + ..acceleration*t..)*ey
This describes the vector.
What if the question wanted me to sketch the vector and find the magnitude and direction of motion with respects to the x-axis?
Sorry for the late reply:
Just sketch an arrow making 30 degrees with the horizontal. Then project the vector onto the x-axis and that's your x-component. It's that easy.
Magnitude of the vector in the x-direction is as you described, 5.4cos30. The direction of motion with respect to the x-axis will be 30 degrees.
