Calculating Blower Flow in CFM - Required Data & Equation
  • Context: High School
  • Thread starter Thread starter Eng.Ayed
    Cfm Data Flow
The discussion focuses on calculating the blower flow in cubic feet per minute (CFM) for a gas turbine's lube oil mist separator blower. Participants seek to identify the necessary data and equations for this calculation, particularly in light of modifications made to the vent line pipe that have affected the system's performance.
  • One participant requests clarification on the purpose of the blower and the specific requirements for calculating flow, suggesting that typically, flow needs are calculated first before selecting a blower.
  • Another participant describes the context of their situation, detailing that modifications to the vent line pipe have led to pressurization issues in the tank that should be under vacuum.
  • A suggestion is made to consider introducing a diffuser to lower the pressure before it reaches the return reservoir, drawing an analogy to pan-evac systems used in automotive applications.
Participants do not appear to reach a consensus on the necessary steps for calculating the blower flow, as there are multiple perspectives on the approach and requirements for the calculation.
Participants have not provided specific equations or detailed methodologies for the flow calculation, and there is uncertainty regarding the exact data needed for accurate calculations.
Eng.Ayed
dears;
happy new year...
I would like to ask you about how can I calculate the blower flow in CFM.
what are the required data that must be available. Also I need the equation that calculate the flow.
Welcome to PF!
You're going to have to give us a lot more information if we are to help you. What is the purpose of this blower? Do you need to select it or do you have it and want to find out what it can do? Typically, people calculate what flow they need, then select the blower out of a catalog or with selection software to math their needs. No calculation required.
Dear Sir;
First of all, we have Gas Turbine and it has a lube oil mist separator blower. It is designed to exhaust air from the oil reservoirs and remove the oil mist entrained in that air via vent line pipe. Before we did not face any problem but we did some modification which was the extended of the vent line pipe after this modification we faced some problem and the most of it was the tank almost pressurized it must be vacuum because of blower. Now we are looking for how can we calculate the flow then we can see it in the performance curve. Finally after this clarification I hope you understand my issue.
please note down all the information may need during the flow's calculation.
your help is highly appreciated
russ_watters said:
Welcome to PF!
Welcome to PF, Eng.
Russ is certainly the guy to listen to on this subject, and Fred Garvin if he's still around.
Since I know nothing about the matter, I'll just chirp up with my normal "outsider" viewpoint. This reminds me very much of the pan-evac systems that we used on our cars back in the day, wherein pipes ran from the valve covers to the headers to eliminate pressure (if good enough, create vacuum) in the crankcase.
Since yours is a closed system, you don't want to lose your oil. Might I suggest, therefore, that you introduce some sort of diffuser that will lower the return to atmospheric pressure before it gets to the return reservoir? (Or is there no return reservoir, and it has to go directly back to the main tank?)
