Calculating Daily Operating Cost for a Motor at Rated Load
To calculate the daily operating cost of a motor at rated load, first convert the horsepower to watts, resulting in 7460 watts for a 10 hp motor. Factor in the motor's efficiency of 87%, which means the actual power input is higher than the output, calculated as 7460 watts divided by 0.87. Multiply the adjusted power input by the number of hours operated (8) to find the total energy consumed in kilowatt-hours. Finally, multiply the total energy used by the cost of electricity (5 cents/kWh) to determine the daily operating cost. Accurate calculations are essential for determining the correct daily cost of operation.
holy_kamote
a motor operates at its rated load of 10 hp for 8.0 h a day. its efficiency is 87 percent. what is the daily cost of operation if electric energy costs 5 cents/kWh?
i convert 10 hp to watts
10 x 746=7460 watts
then i multiply the 7460 with 5 cents and i get 37.3cents/daily cost...
is my answer correct? if not plsss post some idea on how i can solve that ty very much...
help me plsssss. coz we will have a boardwork tomorrow ..
You are missing a couple of things. The motor is operating for 8 hours each day...you didn't factor that in. Also, you didn't factor in the efficiency rating. If the motor is rated at 10 hp , that's how much power you get out of it...but more power has to go into it due to the inefficiency losses within the motor, and that's what you pay for.
what formula will i use to solve this prob?... thanks sir jay for posting in my topic.
Please show an attempt at a solution. If the motor is 87% efficient, the power into the motor is greater than 10 hp. First calculate that number. Then once you get that power, how would you convert it to energy used (kWh) in 8 hours? We can't be of much more help unless you show some attempt. Thanks.
