Calculating Displacement: Magnitude & Direction of a Car's Motion
  • Thread starter Thread starter zyzzxbrah
    Homework Vectors
The discussion focuses on calculating the final displacement of a car that travels north and then east. The car's total displacement was calculated as 492 meters using the Pythagorean theorem. The direction of the final displacement was initially calculated as 13 degrees North of East, which was incorrect. A clarification was provided that the angle should be interpreted as 13 degrees East of North instead. Accurate representation of direction is crucial in displacement calculations.
zyzzxbrah
A car travels north with a velocity of 5.2-m/s for 92-seconds. It then turns east, and with the same speed travels for a further 22-seconds. Calculate the magnitude of the final displacement of the car.
Now give the direction of the final displacement of the car. Give your answer in degrees North of East.
pythargaros
Hi i have calculated the magnitude (492m) by doing 5.2 x 92 and 5.2 x 22 and using pythagaros
For the 2nd part (direction in degrees). I did tan^-1(114.2/478.4) and got 13 degrees. this was wrong
Hello Zbrah, welcome to PF :smile: !
13 degrees North of East ?
I wrote that in my answers, but it was wrong :(
Make a little drawing. You'll immediately see the difference between 13 degrees North of East and 13 degrees East of North...
Likes zyzzxbrah
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
