Calculating Displacement of Robotic Arm Parts in Ansys Workbench
The discussion revolves around calculating the displacement of parts in a robotic arm using Ansys Workbench v.12. Participants explore various tools and methods for measuring displacement and deformation under different loads, focusing on the appropriate use of software features and geometry simplification.
  • A new user seeks guidance on calculating displacement in Ansys Workbench, expressing confusion over the Position tool's results.
  • One participant suggests using the "Total Deformation" tool to calculate deformation and displacement for all bodies, and mentions the possibility of calculating displacements along specific axes.
  • The original poster clarifies their focus on measuring displacement rather than deformation, questioning whether the Total Deformation tool provides a combined value of both.
  • Another participant indicates that to obtain a pure deflection, results should be applied to a single point, as deformation results may include both deformation and deflection.
  • There is a discussion about the complexity of the geometry and the importance of contact conditions, with suggestions to simplify the model for better results.
  • The original poster shares details about their computer specifications and mesh settings, seeking further advice on potential adjustments.
  • The original poster mentions having experimental data for the robot, aiming to create a model in Ansys that closely matches observed behavior.
Participants express differing views on the appropriate tools for measuring displacement and the implications of deformation versus deflection. The discussion remains unresolved regarding the best approach to achieve accurate displacement measurements.
Participants note the complexity of the geometry and the need for careful consideration of contact conditions, but specific assumptions or limitations in the model setup are not fully detailed.
panthalas
Hello, I am a new user both in Ansys and in the forum and I am sorry if my question is silly, but I cannot find the solution by myself.
I am using Ansys Workbench v.12 static structural in order to find the displacement of various parts of a robotic arm, that are caused by different loads.
I have successfully imported the geometry, made necessary changes, defined the connections, the load, the supports etc but I cannot find a tool that can calculate the Displacement of a certain part(the robot consists of many parts) .
I thought that the tool named Position which can be found in
Solution-->insert-->probe-->position would be the one I need, but the results it gives ,min and max value of a coordinate system (one I have placed on a face of the object whose displacement i want to find), are the same as if it didn't move at all.
Could someone please help me? Is this the right tool and I use it in the wrong way or is there another tool for that? I have attached a photo of the robot.
Thanks a lot
Just right-click the solution object and select "Insert - Deformation - Total". This will calculate deformation and displacement for all of the bodies in the system. You can also calculate diplacements along certain axes, and for specific bodies or features.
You're going to want to look into simplifying that geometry too, it's way too complex for the simple calculation you're trying to do (things like bolts can be removed for example). Also pay special attention to contact conditions- fixed conditions may not be what you're looking for at certain interfaces...
Thanks for answering Mech_Engineer.
I have checked the contact conditions (rotations, fixed) and I think they are ok.
In order to simplify, I cut off unnecessary, conserning the strength, things like the bolts you told me.
Consider the fact that when the part I have indicated in the picture is loaded, the biggest deformation is that of the lowest and biggest joint. That deformation-most of all- results in the displacement of the indicated part (whose displacement I want to measure) . That's why I am asking for displacement and not for deformation.
You told me that the ''Total Deformation" tool calculates not only the deformation of the material in that place, but also the displacement of that. So, if I got it right, is that number the sum of deformation and displacement in a place? Does the same apply in the tool called "axial deformation" (in order to calculate the displacement in z-axis)?
About the position tool: is it irrelevant with what I am searching?
Thanks again!
To get a pure deflection, you need to apply a result to a single point. Otherwise as you say, the deformation result is a function of deformation and deflection.
By the way, what kind of a computer are you solving this on, and how big is your mesh?
Ok then, I'll use the total deformation tool then. I am trying to calculate the sum of deformation and deflection at the part I showed in the picture.
The computer is strong: windows 7 ultimate x64, amd athlon II X3 425 processor 3,29GHz, 6GB ram, ATI radeon HD 4200.
The mesh I am using is the automatic Mechanical .I have changed the element size but I don't know what else to change. Check the attached picture. Is there anything you think I should change?
I have experimental data for this robot ( deflections in certain positions with certain loads). I am trying to make a model in Ansys that will have a close behaviour.
Thanks
13K
10K
