Calculating Displacement with Vectors
To calculate the resultant displacement of a car traveling from point A to point C, a vector diagram can be constructed, with the car first moving 6 km east and then 4 km northwest. The correct approach involves breaking down the vectors into their components using trigonometric functions for both the eastward and northwestward movements. The resultant vector can be found by summing the x and y components of the two vectors. The initial measurement of 4.3 km at a bearing of 50 degrees may not be accurate, emphasizing the importance of using calculations over measurements for precision. Understanding and applying the vector component equations is crucial for solving such problems effectively.
Angus Dolan
Hello, I have a homework question that I'm having difficulty with, it is:
A car travels due east (bearing 90) from point A for 6km to point B and then North-west (bearing 315) for 4.0km to point C.
By constructing a vector diagram, or otherwise, find the resultant displacement (magnitude and direction) of the car at point C from A.
I don't think pythagoras theorem works here, as there is no right-angled triangle present. Although, I may be incorrect.
I've drawn a vector diagram, head to tail, and measured the displacement, it comes to 4.3km at a bearing of 50. Is that correct?
You can try other methods of finding vector C, you can find the components of vector A, and vector b
Remember finding the magnitude or resultant vector is
\vec{R} = \vec{A} + \vec{B}
which is really
\vec{R} = (A_{x} ) (B_{x} ) + (A_{y} ) (B_{y} )
A_{y} = (\vec{A}) (sin \theta)
A_{x} = (\vec{A}) (cos \theta)
B_{y} = (\vec{A}) (sin \theta)
B_{x} = (\vec{A}) (cos \theta)
The Ax, Ay, Bx, By equations are derived from this idea
I would plug and chug for you, but I'm kind of confused by the bearings.
Don't rely on measuring the displacement vector. Sometimes the ruler isn't as precise, also it will help you in the long run to have these equations in your tool box.
Let me know if you solved it, or if it helped. So I can get some personal feedback, because I don't want to be misinforming people lol.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
