Calculating Energy of Electron with T=0.0017
  • Thread starter Thread starter vicks
    Electron Energy
The discussion revolves around calculating the energy of an incident electron encountering a potential energy barrier with a height of 5.4 eV and a thickness of 0.73 nm, given a transmission coefficient of 0.0017. Participants emphasize the importance of using the equations for the transmission coefficient and the parameter 'b' to derive the energy. One user expresses frustration over not arriving at the correct answer, initially suggesting a value of 0.203 eV. Others encourage sharing the attempted solution to facilitate guidance and clarify the calculation process. The conversation highlights the complexities of quantum physics and the need for precise calculations in barrier problems.
vicks
Consider a potential energy barrier like that of Fig. 38-15 but whose height U0 is 5.4 eV and whose thickness L is 0.73 nm. What is the energy of an incident electron whose transmission coefficient is 0.0017?
I tried to solve the problem my self but could not get the right answer still having trouble with this question please let me help with this my answer is .203 but not right if some one help me out with this questino and tell me the answer would appreciate that ! thank you very one here are the hint !
The transimission coefficient for a barrier of height U0 and width L is given by
T = e-2bL ...1
Where b = v (8p2m(U0 - E ) / h2 ) ...2
Substituting values in equation (1) we get b
Then substitute b in equation (2) we get E
Givem that U0 = 5.4 eV
m = mass of electron
L = 0.73 nm
T = 0.0017
I hope this may help you.
Quntum physics ! barrier energy !
T = e-2bL ...1
L = 0.73 nm
T = 0.0017
What is fig 38-15? =P
and how did you do to get your answer 0.203 ?
don;t worry about the figure ? its in the book i cannot tell you the right here but has nothing to do with the answer .. acutally .203 i just plugin the values but i am sure i am not right so please help me out i already set up the equation but still getingg problem to solve this problem !or to find of the energy ..
It is straightforward, trivial. You have all values except one right?
Why don't you post your attempt to solution so that we may put you in the right direction instead?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
