Calculating Entrance Lengths in Hydrodynamics
  • Thread starter Thread starter pauleck
    Hydrodynamics
The dimensionless hydrodynamic entrance length is calculated using the formula z+=zh/(Re*Dh), where zh is the hydrodynamic entrance length, Re is the Reynolds number, and Dh is the hydraulic diameter. If the hydrodynamic entrance length zh exceeds the total channel length L, it is not necessary to assume zh equals L for calculating z+. Instead, it indicates that the flow has not fully developed by the end of the channel. Therefore, zh can be longer than the actual channel length without any adjustments needed for z+. Understanding this concept is crucial for accurate hydrodynamic analysis.
pauleck
Hi everybody,
first of all, sorry for any grammatical mistakes, I am a non-native English speaker.
So here is my concern,
the dimensionless (hydrodynamic) entrance length is defined as:
z+=zh/(Re*Dh)
,where zh is the hydrodynamic entrance length, Re is the Reynolds number, and dh is the hydraulic diameter of the duct.
If zh exceeds the total channel length L, do I have to assume zh=L for calculating z+??
Thank you very much
No. The entrance length is longer than the channel length, and the dimensionless entrance length is longer than the dimensionless channel length. zh is not limited to the actual channel length. If zh>L it just means that at the end of the channel the flow hasn't fully developed yet.
Likes Chestermiller
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
