Calculating Equilibrium Concentrations of H+ and HSO3 in SO2-Rainwater Reaction
  • Thread starter Thread starter gunnar
    Ph
The discussion revolves around calculating equilibrium concentrations of H+ and HSO3 in the reaction of SO2 with rainwater, given a concentration of SO2 at 0.16 ppm. Participants clarify that H+ and HSO3 can be treated as having the same concentration due to their insignificant amounts compared to the reactants. To find the concentration of SO2, one should convert the ppm value to molarity, considering standard temperature and pressure conditions. The equilibrium constant is utilized in the equation to solve for x, which represents the concentration of H+. Lastly, it is emphasized that the final answer requires taking the negative logarithm of x to determine the pH.
gunnar
Hi, can someone please give me a hint to this problem?
The concentration of SO2 in the troposphere over a certain region is 0,16 ppm by volume. The gas dissolves in rainwater as follows:
SO2(g) + H2O(l) >> H+(aq) + HSO-3(aq)
Given that the equilibrium constant for the preceding reaction is 1.3e-2. We assume the reaction does not affect the partial pressure of SO2.
I've tried everything I can think of. I am not sure how to handle HSO3 in the equation, is it the same conc. as H+?
In trouble
Assuming the amount of H^+ and HSO_3^- was insignificant compared to after the reaction, it's safe to treat the two reactants as having the same concentration.
OK. I treated them as to be the same conc. But how can I get the pressure of SO2?
You need the concentration of S02, try finding it from the data
Ka=[x][x]/[(concentration~of~S02)-x], solve for x
pH=-log[x]
I solved for x and still don't get it right. I got the pressure of SO2 to be 5,6e-5 atm from the information I got. Used P=nRT/V
Since SO2 is 0,16 ppm it must be 0,16 mg in one liter I assume STP conditions. And I got the MW of SO2 to be 64,07 g/mol
Am I wrong?
why are you using pressure, it's supposed to be in concentration, I'm pretty sure that you can directly convert to concentration from ppm by volume scale. Don't forget to take the negative log of x, this will be your answer.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
