Calculating Equivalent Resistance
To calculate the equivalent resistance in the given circuit, the resistors R1, R2, and R3 must be analyzed in terms of their configuration. The top and bottom parts of the circuit are identical, with each having an equivalent resistance of 27.1 ohms. The total equivalent resistance cannot be simply calculated by treating the two parts as parallel due to the voltage source placement. The correct approach involves determining if the resistors are in series or parallel based on their current and voltage relationships. After reevaluating the calculations, the user successfully derived the correct answer.
PennStateFan1
In the circuit shown in the figure, R1 = 3.23 Ω, R2 = 5.19 Ω, R3 = 23.1 Ω, and V = 10.7 V.
a) Determine a value for the equivalent resistance.
http://img651.imageshack.us/i/p074figure.png/
Parallel is 1/R1+1/R2+1/Rn=1/Req
Series R1+R2+R3=Req
I know how to calculate the equivalent resistance of the top part and the bottom part, which are the same, but how do you calculate the total resistance with the source between the two? Taking them in parallel is obviously wrong.
The equivalent resistance of the top part is 27.1 ohms if that helps explain it to me.
Thanks
Resistors are in parallel if they have the same potential difference, and are in series if they have the same current.
Do either of these cases apply to the equivalent resistors you found for the top and bottom loops?
When I was putting them in parallel I was forgetting to do the 1/Req. Thanks for the advice, as I got the answer when I went back and tried again.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
