Calculating Focal Length Using Sign Conventions for Lenses
  • Thread starter Thread starter oooride
    Lenses Sign
The discussion revolves around calculating the focal length of a lens given the distance between an object and its upright image, which is 20.0 cm, and a magnification of 0.500. The user initially speculates that the lens is a Double-Concave (diverging) lens due to the positive distance indicating the image is closer to the lens than the object. Clarification is provided on using standard sign conventions, where a positive object distance (p) indicates the object is in front of the lens, and a positive image distance (q) indicates the image is on the opposite side. The user is guided to set up equations based on the distance and magnification to solve for the object and image distances, ultimately leading to the calculation of the focal length. Understanding the sign conventions and correctly identifying p and q is crucial for solving the problem accurately.
oooride
Okay for the most part I understand the concepts involved but I'm having some trouble with this question.
The distance between an object and its upright image is 20.0 cm. If the magnification is 0.500, what is the focal length of the lens that is being used to form the image?
Now first I understand since this is an upright image formed (virtual) by the lens, that it is either a Double-Convex (converging) lens with the object between the first focal point (F_1) and the front side of the lens, or it is a Double-Concave (diverging) lens with the object placed anywhere on the front side of the lens.
My guess is that it is a Double Concave lens since the question states the distance between the object and the upright image is +20.0 cm. Since it's positive does this mean that the image formed is to the right (closer to the front of the lens than the object is)?
If so, if it was a -20.0 cm would this mean that it is a Double-Convex (converging) lens with the object between F_1 and the front of the lens, and producing a virtual image to the left of the object?
I'm assuming where I'm confused what type of lens it is in order to use the correct "sign conventions". And the object's distance from the focal point is not given..
What I did was:
M = -q/p
0.500 = -(20.0 cm)/p
p = -(20.0 cm)/0.500
p = -40.0 cm
Also how do I know if 20.0 cm is "p" or "q"? I know that p is the object distance and q is the image distance, but if I have the distance between p and q, how do I know which is which?
Then I used 1/p + 1/q = 1/f to find the focal point.
Any help is greatly appreciated.
Thanks in advance.
let the equations do the work
Here's how to think this through. First off, assume the standard sign conventions, then let the formulas do the work for you. The standard is that a positive p means the object is in front of the lens and a positive q means that the image is on the other side of the lens.
So the first fact, the distance between object and image = 20 cm, can be written as: p + q = 20. (Note: I just assume q is positive--if it's negative, we'll find out.)
The next fact is magnification = .5 (positive because it's a virtual, upright image). So: m = -q/p = 0.5.
Now combine these two equations and solve for p and q. Then find f.
I got the right answer and understand it now.
:biggrin: Thanks!
