Calculating Forces Acting on 4 Spur Gears in a Machine
To calculate the forces acting on four spur gears in a machine driven by an 80kW motor, it's essential to consider the diameters of the gears and their pressure angle of 20 degrees. The input motor operates at 1850 rev/min, and the gear sizes are 100, 300, 133.34, and 266.66 mm. Users suggest utilizing online calculators and resources, such as the Spur Gear Calculator and various engineering websites, to derive the necessary equations and force calculations. Some users have encountered difficulties with software usability and downloading resources. Accurate calculations depend on knowing the geometric factors and applying the correct formulas for spur gears.
Mohhid786
Hi,
i would like some help on how to calculate the forces acting on each gear if the machine had 4
for example gear 1 has a diameter of 100, gear 2 has 300, gear 3 has 133.34 and gear 4 has 266.66
the machine is driven by an 80kW motor through a 2 stage gearbox having four spur gears. The input motor runs at 1850 rev/min and all gears have a pressure angle of 20 degrees
if anyone can give me a helping hand with this it would be of most help thank you
This link might do what you need: Spur Gear Calculator v1.07 http://www.dakeng.com/spurgear.html
It doesn't seem to accept pressure angles directly, but you should be able to derive what you need from the equations here: http://shopswarf.orconhosting.net.nz/spur.html
thanks for the link however its not letting me download it
The full version installed OK for me. On trying it out, it's not as useful as I hoped, though, but perhaps I'm not using it right. Its help file is in an old format and I didn't bother to try to install the old helpfile reader. Googling "spur gear calcultor" gives some other results, but I'm not sure what you need.
http://www.roymech.co.uk/Useful_Tables/Drive/Gears.html#Forces has some force formulas that should help once the other geometric factors are known.
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
