Calculating Forward and Backwards error of the sine function
2 replies · 7K views
harrisiqbal
1. The sine function is given by the infinite series
sin(x) = x - x3/3! + x5/5! + x7/7! + ...
a) What are the forward and backward errors if we approximate the sine function
by using only the first term in the series, for x = 0.1, 0.5, 1.0?
b) Using the first two terms.
Forward Error: Fhat - F
Backward Error:xhat - x
Fhat is the function approximation.
Xhat is the input modification used to calculate the backward error.
This is basically from my Numerical Methods Course.
I don't have any problem with the Forward Error analysis.
For part a. I simply evaluated the original sin(x) function with x = .1 and got a number. Then evaluated the approximation function Fhat = x
[ this is the sin function expanded into the Taylor series.. but only using the first term of the series]
and then I used the F. Error equation to get the answer...
The problem is the backward error where I have to satisfy this equation:
F(xhat) = Fhat(x) Basically I want a xhat that when put into the original sin function will output my approximation function.
I can't figure this out.. at all. I mean. the only time sin(x) = x is when x = 0? or am i wrong? What am i missing here? It has to be trivial!
I mean if my function was the exponential function then my xhat would be log(Fhat) so e^xhat outputs the Fhat function.. that's easy.. but how is that applied to the sin(x) = x condition?
Thanks!
NVM. I feel so retarded.
I figured it out. Obviously it would be the inverse Sin(x) function that would allow me to calculate the backwards error..
SO obvious wow.
You're probably very far from being retarded :smile:
