Calculating IA, IB, IC: A Parameterization Approach
  • Context: Undergrad
  • Thread starter Thread starter squenshl
    Approach Ib Ic
The discussion focuses on calculating the integrals IA, IB, and IC for the function 1/z along specified paths. The line segment A is parameterized using the equation y = x - 1, while the arcs B and C are defined on the circle |z| = 5. The correct parameterization for the arcs involves using polar coordinates, specifically z = 5e^{i\theta}, with limits derived from the angles corresponding to the endpoints. The integral IB evaluates to ipi, while the relationship between the integrals is established through the residue theorem, confirming that the integrals along the curves are interrelated.
  • Complex analysis, specifically contour integration
  • Understanding of parameterization of curves in the complex plane
  • Familiarity with polar coordinates and their application in complex functions
  • Knowledge of the residue theorem and its implications for line integrals
  • Study the parameterization of complex curves in detail
  • Learn about the residue theorem and its applications in complex analysis
  • Explore the properties of analytic functions, particularly 1/z
  • Practice calculating line integrals over various paths in the complex plane
Students and professionals in mathematics, particularly those focusing on complex analysis, contour integration, and related fields. This discussion is beneficial for anyone preparing for examinations or seeking to deepen their understanding of complex integrals.
squenshl
I'm studying for a test.
The question is:
Let A be the straight line segment from -3-4i to 4+3i. Let B be the arc of the circle |z| = 5 going anti-clockwise from -3-4i to 4+3i. Let C be the arc of the circle |z| = 5 going anti-clockwise from -3-i to 4+3i. Define:
IA = \int_A 1/z dz
IB = \int_B 1/z dz
IC = \int_C 1/z dz
How do I calculate IA, IB, IC? I know to write IA as an integral by parameterizing A, but how do I parameterize A, I know if I can find IA then the other two are easy. Could I let z = eit so dz = ieit dt. I can't seem to get the limits integration.
You have:
\int_{-3-4i}^{4+3i} \frac{1}{z}dz
Just figure out the equation of the straight line from start to end. I get simply y=x-1. So let x(t)=t and y(t)=t-1 and solve:
\int_{-3}^4 \frac{1}{x(t)+iy(t)}(dx(t)+idy(t))
|-3-4i|= |4+ 3i|= 5 so they both lie on the circle |z|= 5 but |-3- i|= \sqrt{10}\ne 5 so the circle |z|= 5 does NOT go "from -3- i to 4+ 3i". Did you mean "from -3- 4i to 4+ 3i"? But then B and C are the same!? Perhaps you mean "from 4+ 3i to -3- 4i"? That is, B and C are two halves of the same circle.
Since z= x+ iy is on the circle |z|= 5 if and only if x^2+ y^2= 5, we can use x= 5cos(\theta) and [/itex]y= 5 sin(\theta)[/itex] (which is the same as z= 5e^{i\theta}[/itex] for the circle. The only "difficulty" is getting the beginning and ending values for \theta. At z= 4+ 3i, x= 5 cos(\theta)= 4 and 5 sin(\theta)= 3 so (5 sin(\theta))/(5 cos(\theta))= tan(\theta)= 3/4. For the anti-clockwise circle from 4+ 3i to -3- 4i, \theta goes from arctan(3/4) to \pi+ arctan(3/4) and for the anti-clockwise circle from -3- 4i to 4+ 3i, \theta goes from \pi+ arctan(3/4) to 2\pi+ arctan(3/4).
Sorry C is the arc of a circle |z| = 5 going clockwise from -3-4i to 4+3i.
How do I parameterize z
Is \vartheta the same as for the anticlockwise arc.
Sorry z = 5exp(i\vartheta)
For the anti-clockwise arc I got IB = ipi
Does that mean the clockwise arc is ipi by symmetry
No.. 1/z is not a symmetric function.
It is also not an analytic function (in the origin), and I guess this exercise comes to teach you what it means about its line integrals.
1/z is analytic inside the region determined by the curves A and B and on the curves... so, \displaystyle\int_B f(z) dz - \displaystyle\int_A f(z) dz = 0 (the minus sign is to correct orientation of the curves). So, if you found B, you have A.
Joining C with B (or A, it doesn't really matter), correcting the orientations, you can find the integral using residue theorem (which is simple for f(z) = 1/z, as it's already a Laurent series, and the pole is simple (order 1)). So, if you have B, and the residue, you also have C, and the problem is solved.
