I Calculating Magnetic field strength of a magnet
Calculating the magnetic field strength of a cylindrical magnet involves understanding magnetic flux through a wire loop, typically expressed by the equation Φ=∮BdAcosθ. The challenge lies in determining the magnetic field strength (B) of the magnet, which may require using the Biot-Savart law or simulations like COMSOL for accurate results. The discussion also touches on the magnetization (M) of the magnet, which is essential for applying Maxwell's equations in magnetostatics. The Green's function approach is suggested for solving related equations, providing a method to calculate potentials in magnetostatics. Overall, the conversation emphasizes the complexity of accurately calculating magnetic field strength and the importance of theoretical frameworks in magnetostatics.
Einstein44
I have been trying to calculate the magnetic flux thought a single loop of wire occurring from a magnet (meaning it has a nonuniform field), so I have the following equation:
Φ=∮BdAcosθ
Now my problem is that I do not know how to calculate the magnetic field strength (B)of that magnet (which has a cylindrical shape) in order to find out its flux. I have not seen a clear answer to this on the internet, although I think that is is possible to use the Biot Savart equation in some form to do this?
In general, I think it's pretty hard and usually done via simulation (like with COMSOL). However, I did a Google search on your thread title, and came across this link that seems to have some approximations that may give you what you want:
https://www.magnet-sdm.com/2017/08/01/magnetic-field-strength-permanent-magnet/
Likes Abhishek11235, bob012345, Charles Link and 1 other person
Thank you. Indeed this is the only thing I have come across earlier today. This distance X representing the air gap between the testing points, how is it determined? And how could I find it?? I am a bit confused about this part, maybe you can give me an explanation there.
Likes hutchphd
If it's about magnetostatics there are two general ways to address the problem. I'm assuming a "hard ferromagnet", i.e., you have a given magnetization ##\vec{M}## within the magnet, vanishing outside. Then the macroscopic Maxwell equations for the magnetic field read
$$\vec{\nabla} \times \vec{H}=0, \quad \vec{\nabla} \cdot \vec{B}=0$$
and the constitutive equation (in HL units)
$$\vec{B}=\vec{H}+\vec{M}.$$
(a) Use of a scalar potential for ##\vec{H}##
This works only for this special case of magnetostatics without "free currents", i.e., for ##\vec{j}=0##. Since ##\vec{H}## is then vortex free there's a scalar potential,
$$\vec{H}=-\vec{\nabla} \Phi.$$
Together with the constitutive equation you get
$$\vec{\nabla} \cdot \vec{B}=\vec{\nabla} \cdot (\vec{H}+\vec{M})=-\Delta \Phi + \vec{\nabla} \cdot \vec{M}=0.$$
Since ##\vec{M}## is given by assumption, we have
$$-\Delta \Phi=-\vec{\nabla} \cdot \vec{M}.$$
With the Green's function of the Laplace operator you get
$$\Phi(\vec{x})=-\int_{\mathbb{R}^3} \mathrm{d}^3 x' \frac{\vec{\nabla}' \cdot \vec{M}(\vec{x}')}{4 \pi |\vec{x}-\vec{x}'|}.$$
Integrating by parts gives
$$\Phi(\vec{x})=+\int_{\mathbb{R}^3} \mathrm{d}^3 x' \vec{M}(\vec{x}') \cdot \vec{\nabla}' \frac{1}{4 \pi|\vec{x}-\vec{x}'|} = -\vec{\nabla} \cdot \int_{\mathbb{R}^3} \mathrm{d}^3 x' \frac{\vec{M}(\vec{x}')}{4 \pi |\vec{x}-\vec{x}'|}.$$
(b) Use of a vector potential for ##\vec{B}##
Since ##\vec{B}## is source free there's a vector potential,
$$\vec{B}=\vec{\nabla} \times \vec{A}.$$
Since it is determined only up to a gradient of a scalar field we can impose one "gauge fixing condition", and for static fields the Coulomb gauge is the most convenient one:
$$\vec{\nabla} \cdot \vec{B}=0.$$
Then using the constituent equation we have
$$\vec{\nabla} \times \vec{H}=\vec{\nabla} \times (\vec{B}-\vec{M})=\vec{\nabla} (\vec{\nabla} \times \vec{A}-\vec{M})=0,$$
from which you get
$$\vec{\nabla} \times (\vec{\nabla} \times \vec{A})=-\Delta \vec{A}=\vec{\nabla} \times \vec{M}=\vec{j}_m,$$
which means that the magnetization is equivalent to a current density ##\vec{j}_m##, and again you can use the Green's function of the Laplacian,
$$\vec{A}(\vec{x})=\int_{\mathbb{R}^3} \mathrm{d}^3 x' \frac{\vec{j}_m(\vec{x}')}{4 \pi |\vec{x}-\vec{x}'|}.$$
Likes dextercioby, sysprog and Einstein44
$$\Phi(\vec{x})=-\int_{\mathbb{R}^3} \mathrm{d}^3 x' \frac{-\vec{\nabla}' \cdot \vec{M}(\vec{x}')}{4 \pi |\vec{x}-\vec{x}'|}.$$
from which you get
Wow this is really helpful, thank you very much for your contribution and time.
Likes berkeman
from which you get
what exactly are you referring to with M? I know the magnetisation of the Magnet is N42, which is what I know, so to what units to I have to convert this in order to use this for this equation?
If I understand this correctly, the method a) would be appropriate in this case since the magnet has a "static field", am I correct? So it would be a scalar potential?
I don't know what N42 is. Magnetization is the magnetic-dipole-moment density (magnetic moment per unit volume) of the material.
Yes, in this case the method with the scalar potential is simpler. It applies in regions of space, where the (free) current density vanishes, because
$$\vec{\nabla} \times \vec{H}=\vec{j}_f.$$
Likes Einstein44
But how can I exactly find this out?
The magnetization field or M-field can be defined according to the following equation:
{\displaystyle \mathbf {M} ={\frac {\mathrm {d} \mathbf {m} }{\mathrm {d} V}}}
Is this what you mean?
Likes vanhees71
Yes. That's correct.
would you mind explaining the part with the greens function for the Laplace operator? Maybe like the brief steps, because I had a bit of trouble following along what you did there.
Thanks
The Green's function of the (negative) Laplace operator is defined by the equation
$$-\Delta G(\vec{x})=\delta^{(3)}(\vec{x}).$$
The physicists hand-waving solution is that this is (up to a factor ##Q##) the field of a point charge at rest in the origin. The solution is the Coulomb potential
$$G(\vec{x})=\frac{1}{4 \pi r}, \quad r=|\vec{x}|.$$
This Green's function of "free space" (i.e., no additional boundary conditions along surfaces applied) is usually used to calculate the electrostatic potential from Poisson's equation,
$$-\Delta \Phi(\vec{x})=\rho(\vec{x}).$$
You just have
$$\Phi(\vec{x})=\int_{\mathbb{R}^3} \mathrm{d}^3 x' G(\vec{x}-\vec{x}') \rho(\vec{x}'),$$
because when you evaluate the Laplacian of this expression and using the defining equation you get that Poisson's equation indeed holds for this solution.
A more formal approach to finding the Green's function is to observe that
$$\Delta G(\vec{x})=0 \quad \text{for} \quad \vec{x} \neq 0,$$
and at ##0## there must be a singularity to give the ##\delta## distribution when you apply the Laplace operator to this function.
To find this solution, just exploit the symmetry. Since ##\delta^{(3)}(\vec{x})## doesn't change under rotations around the origin, we should have ##G(\vec{x})=g(r)##. Using the Laplacian in spherical coordinates this implies
$$\frac{1}{r} \frac{\mathrm{d}^2}{\mathrm{d} r^2}[r g(r)]=0 \quad \text{for} \quad r \neq 0.$$
You can just integrate twice to get
$$r g(r)=A+B r \; \Rightarrow \; g(r)=\frac{A}{r}+B$$
with integration constants ##A## and ##B##. Now you want ##g(r) \rightarrow 0## for ##r \rightarrow \infty##. So we set ##B=0##.
To determine ##A## we integrate the defining equation over a sphere of an arbitrary radius ##a## and use Gauss's integral theorem:
$$\int_{K_a} \mathrm{d}^3 x [-\Delta g(r)]=-\int_{\partial K_a} \mathrm{d}^2 \vec{f} \cdot \vec{\nabla} g(r)=\int_{K_a} \mathrm{d}^3 x \delta^{(3)}(\vec{x}) =1.$$
Now from our solution
$$\vec{\nabla} g(r)=\vec{e}_r g'(r)=-\frac{A}{r^2} \vec{e}_r$$
and
$$\mathrm{d}^2 \vec{f}=a^2 \sin \vartheta \mathrm{d} \vartheta \mathrm{d} \varphi \vec{e}_r$$
along the surface of the sphere (in standard spherical coordinates). So finally we get
$$-\int_{\partial K_a} \mathrm{d}^2 \vec{f} \cdot \vec{\nabla} g(r)=\int_0^{\pi} \mathrm{d} \vartheta \int_0^{2 \pi} \mathrm{d} \varphi a^2 \sin \vartheta \frac{A}{a^2}=4 \pi A\stackrel{!}{=}1 \; \Rightarrow \; A=\frac{1}{4 \pi},$$
and again you get the Coulomb potential as a solution
$$G(\vec{r})=g(r)=\frac{1}{4 \pi r}.$$
Likes Einstein44 and Delta2
You got the coulomb potential as a result, but this is different than the result you have mentioned in your first post? Sorry if this is just me being stupid but I don't understand how that result has anything to do with your first one?
In my first post I just used the Green's function. If you have an equation like
$$-\Delta \Phi(\vec{x})=\rho(\vec{x})$$
then the solution is
$$\Phi(\vec{x})=\int_{\mathbb{R}^3} \mathrm{d}^3 x' G(\vec{x}-\vec{x}') \rho(\vec{x}')=\int_{\mathbb{R}^3} \mathrm{d}^3 x' \frac{\rho(\vec{x}')}{4 \pi|\vec{x}-\vec{x}'|}.$$
Likes Einstein44
Note that although Vanhees71's explanation is great it is somewhat unlikely that knowing the formal solution is going to be of much help unless your geometry is very, very simple.
The solution will be in the form of some integral over 3D space and will need to be evaluated numerically for most cases. Hence, in practice it is usually as "easy" to just use e.g. a FEM solver (e.g. COMSOL if you have access to that) to solve the problem directly.
Solving problems involving real-world magnets is far from trivial and is actually still an area of active research since there are some cases where e.g. FEM can't be easily used (e.g. certain deconvolution problems)
Likes hutchphd, Delta2 and Einstein44
Yes you're right, I might just do that. I was unaware of how complex this would be. I wanted to do this mathematically but Ill probably go the easier way to find this out.
Thank you!
A good exercise is the homogeneously magnetized sphere. It's however indeed true, in such cases it's much more economic not to use the explicit solution given above using the Green's function but start from the differential equations, imposing the obvious simplifications from symmetry.
Let's do this problem using the magnetic scalar potential method. In Heaviside Lorentz units we have to solve
We just choose the direction of ##\vec{M}## as the 3-axis of our Cartesian coordinate system. Then we have
$$\vec{M}=M \Theta(a-r) \vec{e}_z.$$
The divergence is
$$\vec{\nabla} \cdot \vec{M}=M \partial_z \Theta(a-r)=-M (\partial_z r) \delta(a-r)=-\frac{M z}{r} \delta(a-r).$$
Now it's most convenient to work in spherical coordinates. With ##z=r \cos \vartheta## we get
$$\vec{\nabla} \cdot \vec{M}=-M \cos \vartheta \delta(a-r).$$
Thus we have
$$-\Delta \Phi=M \cos \vartheta \delta(a-r).$$
To solve this it's obvious that the ansatz
$$\Phi=\phi(r) \cos \vartheta$$
looks promising.
Using the Laplacian in spherical coordinates we get
$$-\Delta \Phi=-\frac{r^2 \phi''(r)+2 r \phi'(r)+2 \phi(r)}{r^2} \cos \vartheta \stackrel{!}{=} M \cos \vartheta \delta(a-r). \qquad (*)$$
This gives
$$r^2 \phi''(r)+2 r \phi'(r)+2 \phi(r)=M a^2 \delta(a-r).$$
Except for ##a=r## this is 0. The general solution is
$$\phi(r)=\frac{A}{r^2}+B r.$$
We must have appropriate singularities at ##r=a##, which means that there are different values for the integration constants for ##r<a## and ##r>a##. Now there's no singularity at ##r=0##. Thus we have ##A=0## for ##r<a##. Further we expect that ##\phi(r) \rightarrow 0## for ##r \rightarrow \infty##, and thus we have ##B=0## for ##r>a##. So we find
$$\phi(r)=\begin{cases} Br & \text{for} \quad r<a \\
\frac{A}{r^2} & \text{for} \quad r>a. \end{cases} \qquad (**)$$
To find ##A## and ##B## we have to look at Eq. (*) again. The ##\delta## distribution singularity on the right-hand side must come from the highest derivative on the left-hand side. So ##\phi''## has some ##\delta(r-a)## singularity and thus ##\phi'(r)## must have a jump at ##r=a## and ##\phi(r)## itself is continuous at ##r=a##.
Continuity at ##r=a## implies from (**)
$$B a=\frac{A}{a^2}.$$
Integrating (*) over a small intervall ##(a-0^+,a+0^+)## leads to
$$\phi'(a+0^+)-\phi'(a-0^+)=M.$$
With (**) this gives
$$-\frac{2A}{a^3}-B=-M \; \Rightarrow \; B=\frac{M}{3}, \quad A=\frac{M}{3} a^3.$$
Finally we have
$$\phi(r)=\begin{cases} M r /3 & \text{for} \quad r<a, \\
M a^3/(3r^2) & \text{for} \quad r>a.
\end{cases}$$
Finally plugging this in our ansatz we get
$$\Phi(\vec{x})=\begin{cases} \frac{M z}{3} & \text{for} \quad r<a \\
\frac{M a^3 z}{3r^3} & \text{for} \quad r>a.\end{cases}$$
The magnetic field then reads
$$\vec{H}=-\vec{\nabla} \Phi=\begin{cases} -\frac{M}{3} \vec{e}_z & \text{for} \quad r<a \\
\frac{M a^3}{3 r^5}(3 z \vec{r}-r^2 \vec{e}_z) & \text{for} \quad r>a.\end{cases}$$
So inside you have a constant magnetic field and outside a dipole field:
$$\vec{B}=\vec{H}+\vec{M}=\begin{cases} \frac{2M}{3} \vec{e}_z & \text{for} \quad r<a \\
This is all in Heaviside-Lorentz units!
  • Love
Likes Einstein44 and Charles Link
Φ=∮BdAcosθ
This discussion seems very general. Do you have a specific orientation of the magnet to the loop that you want to tell us? For example if the cylindrical magnet is in the center of the loop or off axis? Is the loop diameter much larger than the magnet or about the same size?
Also, If you have a specific magnet it was manufactured by some company. If you have that information they may be able to provide you with a model of the field. Here is some information on N42 magnets.
https://www.stanfordmagnets.com/everything-you-should-know-about-n42-neodymium-magnets.html
I think the remenance ## B_r ## could be an important value here. With ## B=\mu_o H +M ##, (if I'm not mistaken), it gives the value of the approximate ## M ## for the magnet. For N42 I see one data sheet that gives it as from 1.28 to 1.32 T. (See also post 2 of this thread by @berkeman ).
(Note: Sometimes the units are given with the formula ## B=\mu_o H+\mu_o M ##, so that care must be taken in using published formulas that involve ## M ##, to keep the units straight).
Likes Einstein44 and hutchphd
bob012345 said:
Also, there is this Wolfram demonstration project of the field of a cylindrical bar magnet.
https://demonstrations.wolfram.com/MagneticFieldOfACylindricalBarMagnet/
I just read this post. Here they gave the two equations attached below. Which one is for what? I see they are pretty similar but have some slight differences to them. In theory, can I just substitute values into this equation and obtain the value for B that I am looking for??
The magnet is falling through the loop at an angle of 0 degrees and at the center of the loop indeed. The loop had a diameter of approximately 3.5cm where the magnet has a diameter of 15 mm.
@Einstein44 To answer your post 25, you only need to look at ## B_z ## for your geometry. In those formulas, they are computing ## B_z ## and ## B_r ## by integrating over the surface of the two endfaces of the magnet where there is magnetic surface charge density ## \sigma_m=\pm M ##.
Likes Einstein44
Thank you. My only problem is finding M now. I know there is an equation
$$\frac{dm}{dV}$$
However this one doesn't really help me because I don't know how to get the value of m (dm=elementary magnetic moment)
So after some further research I found that M can be calculated using I=M/V --> M=IV
where V=volume of magnet, I=Intensity of magnetisation of a bar magnet
And again I don't know how I can find I, so I kind of arrived at a point where I don't know what to do.
Any Idea how some value could be obtained or how I could find M?
This is really the only variable I need to know now to be able to calculate everything I need for my project I believe.
.See post 24.
Charles Link said:
.See post 24.
So that means M would be
$$M=\frac{B}{\mu _{o}}-H$$
$$M=\frac{1.30}{4\pi \times 10^{-3}}-H$$
And now I still have the unknown H?
Sorry if this is me being stupid right now or if I misunderstood what you meant.
I done know if the remenance Br you mentioned is the B in the equation...
  • #31
Set ## H=0 ##. Meanwhile ## \mu_o=4 \pi ##E-7.
  • #32
How can you set H=0? Just by assumption?
  • #33
Einstein44 said:
In the center of a long cylindrical magnet, far from the poles that are at the endfaces, ## H \approx 0 ##. When they give you ## B_r ##, this is basically ## M ## or ## \mu_o M ##, depending on the units they use.
Likes Einstein44
  • #34
Ok thank you very much Sir.
Quick question about the equation for B that we discussed earlier,
what does $$\rho$$ represent?
and what is z? some sort of z component? and how do I find that?
The R was also not mentioned on the article? what exactly doesn't that represent?
I think after that I should be able to proceed with the calculations.
  • #35
They are computing ## B=\mu_o H ##, where ## H ## is computed just like ## E ##, but for magnetic charges, ## \mu_o ## replaces ## \epsilon_o ##.
## R ## is the radial location on the endface of the cylinder over which ## dA=R \, dR \, d \Phi ## is integrated.
The endfaces have magnetic surface charge density ## \sigma_m=\pm M ##.
## \rho ## is the radial distance in cylindrical coordinates of the point of observation where the field is computed.
One additional item: I like to use ## B=\mu_o H+M ##. They use ## B=\mu_o H+\mu_o M ##, so that their ## \mu_o M ## is my ## M ##.
After computing ## H ## at some observation point outside the material, you then compute ## B=\mu_o H+M ##, but this ## M ## is zero, (outside the material), so ## B=\mu_o H ##.
  • #38
so let me recap right here to check if I am understand this correctly.
From my understanding of cylindrical coordinates, the point z in the equation is simply going to be the height of the cylinder?
For ## \rho ##, usually represents the radio of the cylinder? But in this case you said it is the point where the field is computed. Does this mean ## \rho ## is the distance form the center of the magnet to the point on the coil, as this is where it interacts with the magnetic field of the magnet?
Now what you said about ## R ## I must admit I wasn't able to understand, so I would appreciate if you could formulate this very simply and how I can find this out?
  • #39
I think this thread is kind of going in circles and it is not very clear what the problem you want to solve actually is totally. That makes it hard to help you. I understand you want the flux through a loop of wire of an N42 magnet but is it at one point in time of a moving magnet or is it fixed?
Please, let's back up and refresh what we know. Please clearly state exactly what you are trying to do, maybe even draw the problem and tell us what you know and what exactly you are trying to find out. If it is a homework problem please show us the actual problem.
To answer the immediate questions above, ##z## and ##\rho## are coordinates in a cylindrical system. You should review cylindrical coordinate systems to get the right orientation to the symbols.
https://en.wikipedia.org/wiki/Cylindrical_coordinate_system
  • #40
So I am going to start from the beginning now:
My aim is to find the induced emf as a cylindrical N42 magnet falls through a coil of N loops.
To calculate this I use Faradays Law.
Now for that, I need to find the magnetic flux in the first place using the equation:
$$\phi =\oint BdAcos\theta$$
This is why I am now trying to find B for the magnet, in order to work out this problem.
I am attaching a picture below that might perhaps help with visualisation.
So yes, indeed involves a moving magnet.
Likes bob012345
  • #41
They are summing (integrating) all the contributions to ## B ## (or ## H ##) at a point ## (\rho,z) ## where with cylindrical symmetry, it is independent of ## \phi ##). The radial distance ## \rho ## is measured perpendicular to the z axis. The magnet has center at the origin, with endfaces at ## z=\pm L/2 ##.
The magnet has radius ## a ##, and ## R ## is the radial variable on the endface.
The ##B_z=\mu_o H_z ## is readily computed using the pole model=they used a different approach using the gradient of the magnetic potential, but here I do prefer just computing ## H ## how the electric field ## E ## is computed. You should be able to follow how they did the integral over ## R \, dR \, d \Phi ## in polar coordinates. To get the z-component, there is a simple factor tacked onto the inverse square.
Likes Einstein44
  • #42
This is what I mean though, if ## \rho ## is measured perpendicular to the z axis from the center at the origin, isn't that simply the radius (it goes from the center of the magnet to one end of the circle on top of the magnet)? That can easily be measured? I've drawn this out and this is what I am seeing.
Now I don't understand what "## R ## is the radial variable on the endface" means, as I have not come across this term yet...
  • #43
The magnetic charge is spread out over the surface of the endface. Let's work it in (x,y,z) coordinates. The z component of the magnetic field ## B_z ## is computed at (x,y,z). Each element ## dx'dy' ## on the endface surface contributes a different amount to ## H ## or ## B ## because of the distance factor, and the direction that the ## H ## points is different as well. (Presumably you are somewhat familiar with the analogous problem with electric charges to compute the electric field ## E_z ##).
Note: ## dx'dy'=R \, dR \, d \Phi ##.
  • #44
Yes, I understand what you are saying about H and B being different at different points along the magnet. But what exactly does that mean in terms of the variables. I am having trouble understanding how exactly I can measure these components/ what I need to do... I get for example what you are saying about ## \rho ## being measured from the center and perpendicular to the z-axis... But so how is that different from a radius... Do I have to measure this further to some point where the field lines are or what?? I was just looking for a simple answer but I must admit I am quite confused with some of the stuff right now.
  • #45
You just need to compute the flux, (using the z component of ## B ##), through a loop at distance ## z ##:
Flux ## \phi=2 \pi \int\limits_{0}^{b} B_z(\rho) \rho d \rho ##, where ## b ## is the radius of your coil.
First you of course need to compute ## B_z(\rho) ## for each ## \rho ##, (I would suggest about one hundred increments or more), because you don't have a simple expression for ## B_z(\rho)##. That computation also involves a numerical integration, (over ## R \, dR \, d \Phi ##. (see the first "link" of post 25)). (## B_z(\rho) ## could be approximated if you considered your magnet to consist of two point poles that are on-axis, and you could then avoid the surface integral, but it really shouldn't be too difficult to numerically compute this double integral over the surfaces of the endfaces. (Edit note: I tried to do this simplified case in post 54, but it's not an ideal approximation)).
Edit note: ## B_z(\rho) ## above is actually ## B_z(\rho, z) ##.
Likes Einstein44
  • #46
First you of course need to compute ## B_z(\rho) ## for each ## \rho ##, (I would suggest about one hundred increments or more), because you don't have a simple expression for ## B_z(\rho)##. That computation also involves a numerical integration, (over ## R \, dR \, d \Phi ##). (## B_z(\rho) ## could be approximated if you considered your magnet to consist of two point poles that are on-axis, and you could then avoid the surface integral, but it really shouldn't be too difficult to numerically compute this double integral over the surfaces of the endfaces).
so are you referring to the distance z as the distance from the magnet to the coil?
And for the second part, what type of increments? Like in what direction? Horizontal? I am still as confused about what exactly you mean.
  • #47
Ok, thanks. This makes the problem not simpler but at least straightforward.
Is that just some photo you found or is it your own setup? I ask because if it is your setup perhaps you already have data to compare to your calculation when that is done.
My recommendation is to forget the loop and any motion for the moment and just calculate the magnetic field from this combined magnet in 3D space for all space in cylindrical coordinates. First pick a convenient location for the origin. There should be enough to informatin above to do that.
After that you will introduce the loops into the picture and calculate the flux at any point along the axis.
Then, since the induced ##emf = - \frac{d\phi}{dt}##, you can move the loop along the axis. The motion of the loop if it is falling is controlled of course by gravity or you can study it for different assumptions, like a fixed velocity for comparison.
  • #48
Yes, this is a picture of my own setup, and yes I am aiming to test results using this setup and have already collected data.
Now as you know I am just trying to find the magnetic field. The origin of what exactly are you taking about? I assume you understand the posts above better than me, so perhaps you could give me a more simple explanation on what the components ## \rho ## , ## z ## and ## R ## represent? I have been trying to figure this out using the posts from @Charles Link , which are really great but somewhat complex to understand for me...
  • #49
z for these formulas is the distance from the center (midway point) of the magnet.
For increments, I'm referring to a numerical integration where for the simplest case you use rectangles, and compute the area under the curve, where the values of ## B_z(\rho) ## are at the midpoints (in ## \rho ##) of the rectangles.
Likes Einstein44
  • #50
You are getting help on multiple levels at once here. I hope it's not too confusing!
The calculation of the magnetic field everywhere in 3D space is needed in order to know what it is in the loop as the magnet moves through the loop. It is a very difficult calculation. What is your EM background level?
The components ## \rho ## , ## z ## and ##\theta## are the variables of the cylindrical or polar coordinate system. I believe ##R## was used above just to represent integration over the radius of the magnet.
The problem will be ill defined until you establish a fixed coordinate system to work in. That means placing the magnet in that coordinate system say, with the exact center of the magnet at the origin.
