Calculating Magnetic Force on an Object in a Solenoid?
The discussion revolves around calculating the magnetic force on a magnetic ball placed within a solenoid with current flowing through it. The scope includes theoretical considerations of magnetic fields, material properties, and the effects of different configurations within the solenoid.
  • One participant inquires about the method to calculate the magnetic force on a ball within a solenoid.
  • Another participant notes that the magnetic field inside a solenoid is constant and emphasizes the importance of the ball's material properties, questioning whether it is a ferromagnetic material or a permanent magnet.
  • It is mentioned that the magnetic field can be significantly enhanced by using a highly permeable core within the solenoid.
  • Questions are raised about the behavior of the system under various conditions, such as the effect of inserting an iron core, the equilibrium position, and the consequences of turning off the current.
  • A participant clarifies that the object in question is a Neodymium N48 magnet, indicating that it is an actual magnet rather than a ferromagnetic material.
  • One participant expresses difficulty in finding specific calculations for the force in Newtons on the object with known permeability within the solenoid.
Participants do not reach a consensus on the specific method to calculate the magnetic force, and multiple viewpoints regarding the material properties and configurations remain present.
There are limitations in the discussion regarding the assumptions made about the magnetic properties of the ball and the specific conditions under which the calculations are to be made. The discussion does not resolve the mathematical steps necessary for calculating the force.
Integrated
Let's say I have a magnetic ball within a solenoid that has current passing through it. How would I calculate the magnetic force on the ball?
For a solenoid the internal field is constant: http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/solenoid.html
The force on the ball depends upon the material (it's magnetic permeability) - do you mean that it is a ferromagnetic material (soft iron, iron nickel, etc), or that the ball is an actual magnet?
Note that the magnetic field inside the solenoid can be vastly increased by including a highly permeable core:
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/elemag.html
What would happen if an iron core were fully inserted into the solenoid? What is the equilibrium position?
Hold the solenoid vertically - what would happen?
Here is an easy one: if the current is turned off, what happens?
Start with the iron core at rest just below the solenoid, then throw the switch to start the current. What happens?
See this lecture for "the force produced by a magnetic field".
It'll have to be an air core (since something will be inside it) and inside will be a Neodymium N48 nickel-plated quarter-inch diameter ball, so it's an actual magnet.
Then if you've worked through the material posted, and the questions ... you should be good!
I apologize if I missed something, but I can't find what I need in those articles. I'm looking for how to calculate the force, in Newtons, on an object with known permeability within the solenoid caused by the known magnetic field. I greatly appreciate any help you can offer.
  • · Replies 21 ·
  • · Replies 17 ·
