Calculating Mass Flow Rate of a Fluid in a Pipe
To calculate the mass flow rate of a fluid in a pipe, use the formula: mass flow rate = density * area * velocity. The density can be derived from the specific volume, where density equals 1 divided by the specific volume. For a pipe with a diameter of 38mm and a flow velocity of 5 m/s, the calculated mass flow rate is approximately 5.202 kg/s. It's important to ensure that all units are consistent and to understand the relationship between the variables involved. Understanding the underlying principles of fluid flow is crucial for accurate calculations.
felixj500
Hi, how do i work this one out?
The mass flow rate of a fluid flowing through a section of pipe with a diameter of 38mm at a flow velocity of 5ms-1 with a specific volume of 0.00109 m3/kg is?
Thanks,
density = 1 / specific volume
mass flow rate = 5.202 kg/s
is that right?
You have:
Pipe diameter
Flow velocity
and sp.Vol.
Look at your units, then look at the units of the answer you expect and try to work it out. Equations are not enough, try to understand what is happening.
You've got a mass of liquid flowing through a pipe at a certain velocity, yea? The pipe has a given cross sectional area, and a specific amount of liquid will pass through a given cross section at any time, given the flow velocity, right?
So think about how you can relate these variables into something usable.
Also, yep. That's correct. Do you understand how that formula makes sense, though?
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
