Calculating Maximum Bending Stress for a Beam - I'm Doing it Wrong!
6 replies · 4K views · last reply
songtoan92
bending stress in beam, help me !
singularity function
bending stress (max) = { (M max)/I } * ( a/2)
after writing the singularity function, and compute reactions force I found that the maximum bending moment should be 12.04 kNm
I = 1/12 ( 0.1 * 0.14 ^ 3 - 2 * 0.06 * 0.04 ^ 3 ) (m ^ 4)
y/2 = 0.14 /2 = 0.07 m
therefore, the maximum bending stress is ~ 37.9 MPa
but this is totally wrong :( :(, can anyone help with
thank you very much
Hi songtoan92, welcome to PF. Your maximum bending moment looks fine. Make sure to use the parallel axis theorem when subtracting the moment of inertia of the missing areas of the cross-section, though, since they're not centered on the centroid of the beam. Know what I mean?
Can you explain me more ?? I am a little bit confused now
Personally , I think , " I " is the 2nd moment of area, so considering the " H " cross-section of the beam I got I =... I think it does not a matter of moment of parallel axis theorem here ?
Moment of inertia is another common name for second moment of area.
In any case, your calculation of I involves subtracting two areas of 60 mm x 40 mm. But the second moment of area of these regions is not simply [itex]wh^3/12[/itex] because their centroids do not coincide with the centroid of the beam. Rather, their centroids are 50 mm away from the beam centroid. So I is calculated as [itex]I=wh^3/12+whr^2[/itex], where [itex]r=50\,\mathrm{mm}[/itex]. (This is called the http://en.wikipedia.org/wiki/Parallel_axis_theorem" .) Try this and see if you get the answer you're expecting.
So,...
I1 (of the outer rectangular) = 1 / 12 * 0.1 * 0.14 ^ 3 + 0.1 * 0.14 * 0.05 ^ 2
I2 (of the inner rectangular) = 1 / 12 * 0.06 * 0.04 ^ 3 + 0.04 * 0.06 * 0.05 ^ 2
and the I final = I1 - 2I2 ~ 4.5 * 10E-05
is that right ??
You don't need to use [itex]r=50\,\mathrm{mm}[/itex] for the large rectangle. Its centroid coincides with the beam centroid.
I 've got it, thank you for your help :D
