Calculating Most Probable Point of Rupture on a Falling Pole
The discussion revolves around calculating the most probable point of rupture on a 30-meter falling pole pivoted at the bottom. Participants express uncertainty about how to approach the problem, indicating it may be beyond their current physics knowledge. Key insights mention that as the pole falls, forces acting perpendicular to it contribute to potential rupture points. The conversation highlights a lack of clarity on how to visualize or solve the problem effectively. Overall, assistance in understanding the mechanics involved in determining the rupture point is requested.
Jamadar
A thin uniform pole of length 30 m is pivoted at the bottom end. Calculate the most probable point of rupture on the pole as the pole falls.
I'm really not sure how to start.
None, our professor gave us this as a challenge problem and I don't believe it is something I should know taking general physics. Clarification on even where to start would be nice.
Have you found out how to solve this yet? I have no idea.
Still nothing.
Damn. I'm not even sure what this is supposed to look like. No figure or anything.
So I got some more information if anyone still is helping.
while the pole is falling, at any location of the pole there are forces that try to snap the pole. One goes up perpendicular to the pole and the other comes down perpendicular to the pole. That is why an old fragile pole breaks down while its falling full-length. These forces snap the pole into two pieces.
I'm still not exactly sure how to go about finding the rupture point off of this so it be great for help.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
