Calculating Net Force: Equilateral Triangle with Point Charges
To determine the net force on a +1.0 nC charge at point P2, located 3.0 m from two -40 nC charges forming an equilateral triangle, Coulomb's law is applied. The calculations involve finding the forces exerted by each charge on the +1.0 nC charge, breaking these forces into horizontal and vertical components. The resultant force is found by adding the x and y components from both charges. The final calculated net force is 4.4 x 10^-8 N, which appears to be verified through the outlined steps. This approach effectively utilizes vector addition to arrive at the correct solution.
psruler
Hi,
Can anybody help me get started on this problem?
Point P2 is located 3.0 m away from each -Q (-Q = -40 nC) , forming an equilateral triangle with them.
Determine the net force (magnitude and direction) that would act on a small charge of +1.0 nC placed at P2.
Any hints?
Thanks!
Draw a picture and use Coulomb's law. Make use of verical and horizontal components.
Right. Draw the vector for the force that each other charge applies on the +1.0 nC charge (using Coulomb's law), then add them together in a vector addition to find the resultant.
The answer i got is: 4.4 x 10^-8N.
Can you verify if that's right?
Here are the steps I did to calculate that:
F12 = k(q1)(q2)/r^2 = [(8.99 x 10^9)(1.0 x 10^-9)(-40 x 10^-9)]/(3.0)^2
F12x = F12cos56 = (4.0 x 10^-8)(0.56) = 2.2 x 10^-8
F12y = F12sin56 = (4.0 x 10^-8)(0.83) = 3.3x 10^-8
F13 = 4.0 x 10^-8
F13x = 2.2 x 10^-8
F13y = -3.3 x 10^-8
F1x = F12x + F13x = (2.2 x 10^-8) + (2.2 x 10^-8) = 4.4 x 10^-8
F1y = F12y - F13y = 0
F= (F1x^2 + F1y^2)^1/2 = [(4.4 x 10^8)^2 + (0)^2]^1/2 = 4.4 x 10 ^-8N
THANKS!
