Calculating Overall Power in Nd/YAG Laser
  • Thread starter Thread starter nachos1
    Laser Power
To calculate the overall power of a Nd/YAG laser operating at a 10 Hz repetition rate with a pulse energy of 150 mJ, the formula P = E/t is used, where E is energy and t is time. The time per pulse is determined as t = 1/f, resulting in t = 0.1 seconds. The energy per pulse is converted to watts, yielding P = 150 mJ / 0.1 s, which equals 1.5 J/s or 1.5 watts. Clarification is made regarding the use of symbols, ensuring that P represents power and E represents energy. The discussion emphasizes the importance of correct unit representation in calculations.
nachos1
In the units of watts (J/s) calculate the overall power of the laser light generated by Nd/YAG laser operating with a 10 Hz repetition rate in the third harmonic (355nm) at 150mJ per pulse
I can't figure out how to do this problem see attempt below:
I know the following:
Power= E/t=J/s=watt
E=hc/wavelength
E=(Hz)(6.626E-34 J/s)
ok so I think i figured it out
f=10Hz
t=1/f
t=0.1 sec
E=150mJ/0.1 sec
E=1.5 J/s
is that correct?
I think so, but note that you used E for energy in the statement of the problem and now you're using E for power.
ah yes you are correct, it should of been P=W/s not E
Yes, P for power. But now your units aren't correct if W is watts. 1W = 1 J/s. (or is W for "work"?)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
