Calculating Potential Energy Changes in a Roller Coaster System
The discussion revolves around calculating the gravitational potential energy (GPE) changes of an 800 kg roller-coaster car moving from point A to point B. The initial calculations presented are incorrect, particularly in the use of the angle and the height change. The correct height change is determined to be 9.6 meters, which should be used in the GPE formula. Participants emphasize the importance of correctly interpreting the angle and height in the calculations to arrive at the right potential energy values. Accurate application of these concepts is crucial for determining the energy changes in the roller coaster system.
Tmtamrak
A 800 kg roller-coaster car is initially at the top of a rise, at point A. It then moves 135 ft, at an angle of 40.0° below the horizontal, to a lower point B.
(a) Choose the car at point B to be the zero configuration for gravitational potential energy of the roller coaster-Earth system. Find the potential energy of the system when the car is at points A and B, and the change in potential energy as the coaster moves.
GPE = mgy cos theta
This is my attempt to solve, however I keep getting that my answer is wrong.
(800kg)(9.8)(41.15m)x cos 40 =247,138.19J
Can someone please let me know what is incorrect in my process?
GPE = mgy cos theta
Suppose that the angle is zero degrees below the horizontal. What would be the height change?
Now put zero into your formula instead of 40.
Why is it different? Just becos.
The height changes by 9.6m...
If I do (800kg)(9.8)(41.15m) = 322,616J
.. but that is not the correct answer either.
0 degrees from horizontal is horizontal...
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
