Calculating Power Dissipation for a High Power Laser in Manufacturing
The discussion focuses on calculating power dissipation for a high-power laser used in manufacturing. The laser has a beam diameter of 1.5 mm and an electric field amplitude of 0.854 MV/m, leading to calculations involving intensity and area. Initial calculations yielded varying power outputs, with confusion arising from the area formula used for the circular beam. Participants clarified that the correct area for a circular beam should be π(D/2)², not 4πr². The final power calculation resulted in an estimate of around 1710.59 W, which the user believed to be correct.
akmphy
High power lasers in factories are used to cut through cloth and metal. One such laser has a beam diameter of 1.5mm and generates an electric field at the target having an amplitude of .854MV/m.
speed of light= 3.0e8 m/s
permeability of free space is 4pi x 10-7 TN/A
What is the power dissipated?
P=SA
S= c(permeability of free space)E^2
Erms= 1/sqrt2(E)
I first solved for the magnetic field, B= E/c, and got .002849T(this is correct).
I then solved for intensity, S, by calculating the R and B rms, and then using, S= c(permeability of free space)E^2. I got 9.6817e8 (this was correct).
I then calculated the power by using P= SA, and I got 6843.59 W.
What am I doing wrong? Thanks for any help
If your S is 9.68 x 108 W/m2 and your beam area 1.5mm square, then your power should be in the neighborhood of 2200W. Check your area conversion perhaps?
So, S, intensity is 9.68e8, and the beam diameter is 0.0015m:
P = AS
= [(4pi)(.0015)^2][ S]
= 27369.55 W
I tried this one and it was wrong.
I tried dividing the diameter by two to get the radius:
P= AS
= [4pi (7.5e-4)^2]
= I got 6842.39
This was wrong.
I tried the area of a square, and not a circle shaped beam:
= .0015^2
= I got 2178W
Not correct.
Please help me with this. I already submitted the homework, but this is driving me crazy.
Thanks.
For a circular cross section, the area would be πr2, or π(D/2)2, no? Where is your factor of 4π coming from?
I was approaching the laser like an imaginary sphere, so I think I was using the formula of 4pir^2. So, a cross sectional area...just an area of a circle?
P= 9.68e8 (.0015/2)2(pi)
I get 1710.59 W.
I already turned it in; is this the correct answer?
Thanks for your help
I get 1710.59 W.
Sorry, I don't know for sure. But it "feels right" to me.
Thank you so much. I think it is right,too.
