Calculating Power Output of a Weightlifter
To calculate the power output of a weightlifter lifting 250 kg over 2.00 m in 2.00 seconds, the correct formula for work is Work = mass x gravity x height (W = m*g*h). The gravitational force (g) is approximately 9.81 m/s², which must be included in the calculation. The correct work done is 250 kg x 9.81 m/s² x 2 m, resulting in 4905 J. Dividing this work by the time of 2 seconds gives a power output of 2.45 kW. Including the gravitational force is essential for accurate calculations.
lonlyincolleg
A weightlifter is able to lift 250 kg 2.00m, in 2.00s. What is his power output?
W=M x N
P = W/Change t
250 x 2 = 500 (I thought that this was work) so then I divided by time (2.00s) to get power. The answer is not right. It should be 2.45 kW. Please tell me what I am doing wrong.
Work = m*g*h, you missed a "g" in there, so you are off by a factor of 9.81
I got it. thank you!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
