Calculating Pressure: Solving a Company Problem with an Experimental Setup
An intern is seeking help to calculate the pressure in a 150cm3 can of chemical precursor after introducing N2 from a 20 psi line for 20ms. The ideal gas law appears inadequate due to expected pressure and temperature changes during gas introduction. Clarification is needed on whether the 150cm3 refers to the total empty space in the can, as the presence of the chemical precursor could affect volume calculations. The flow rate of the nitrogen is crucial for determining the amount of gas introduced and the resulting pressure. A practical suggestion is to use a pressure indicator for direct measurement during the experiment.
purplebird
i am an intern in a company looking to find the solution to a problem.
I have an experimental setup with a 150cm3 can of chemical precursor with a evacuated pressure of 0.01 Torr
We are introducing N2 from a 20 psi line with a stop valve for a duration of 20ms.
The question is what is the pressure in the bottle after 20ms of N2 introduction?
I am not too sure what the approach is.
I tried to do a simple PV = nRT but it does not get me anywhere.
Any help would be well appreciated.
I don't know the answer as well, but I'll offer my view on this.
The ideal gas law doesn't seem to be applicable here, as there will be a pressure and temperature increase as the gas enters the can.
Also, is the 150cm3 the total empty space in the can? Because you mentioned there being a chemical precursor inside the can. It could affect the actual volume.
Also, what is the flow rate of the nitrogen?
CMIIW, but this is my take on the situation: as the pressure in the can will eventually even out with the pressure of the inlet, then it is important for us to know the flow rate of the nitrogen, so we can calculate the amount of nitrogen in the can after 20s, and thus the pressure.
Alternatively, since you mentioned that this is an experiment, why not simply attach a pressure indicator?
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
