Calculating Projectile Motion Time and Distance with Angle 37 Degrees
To calculate the time and distance of a projectile launched from a 125 m cliff at an initial speed of 105 m/s at a 37-degree angle, first split the initial velocity into horizontal and vertical components using trigonometry. The vertical component is used to determine the time of flight, considering the initial velocity, acceleration due to gravity, and the final vertical position of -125 m. After finding the time, use the horizontal component of the initial velocity to calculate the horizontal distance traveled using the equation d = v1t + 1/2at^2. Right-triangle trigonometry is essential for determining the vector components, where the sine and cosine functions relate the angle to the opposite and adjacent sides of the triangle. This method provides a clear approach to solving projectile motion problems effectively.
Drey0287
A projectile is shot from the edge of a cliff 125 m above ground level with an initial speed of 105 m/s at an angle of 37 degrees with the horizontal. What is the time it takes the projectile to hit the ground? How far from the base of the cliff does it land?
Now my major problem is that I don't know how to set up the motion equation using the 37 degrees...help! I've done the problem before and I turned it in and it was wrong.
Split the initial velocity into horizontal and vertical components. Use the vertical component to find the time of flight. Let's assume that you define up as positive and down as negative: you'll know the initial velocity, the acceleration, and the final position (-125 m). From that, you can find the time.
Once you have that, use the horizontal component to find the distance: you'll have the initial velocity, the acceleration (which should be obvious), and the time.
figure out the x and y components then then put it into the equation d=v1t+1/2at^2
but how do I find the vector components,...im so confused!
Use right-triangle trigonometry. Sketch a right triangle with the hypotenuse as the initial velocity - the 105 m/s. Remember, then, that the sine of an angle is the opposite leg divided by the hypotenuse and the cosine is the adjacent leg over the hypotenuse.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
