Calculating Protons after 2 Seconds - R and C Values
  • Thread starter Thread starter chevycamaro1987
    Protons Seconds
To calculate the number of protons on a capacitor plate after 2 seconds with given values of capacitance (C=1x10^-5 F) and resistance (R=1x10^6 ohms), the mean life is found to be 7 seconds, and the half-life is 10 seconds. The charge at t=0 is 1.60 x 10^-16 C, which can be related to voltage using the equation V = Q/C. The voltage over time can be expressed with the RC discharge equation V = V_o e^(-t/τ), where τ is the time constant. To find the charge at 2 seconds, one needs to apply the decay equations correctly, ensuring to relate voltage to current and charge appropriately. The goal is to derive the final charge to determine the number of protons, which is indicated to be 820.
chevycamaro1987
1. A capacitor where C=1X10^-5 F and R= 1X10^6, there's 1000 electrons on the plate at t=0. How would I find the number of protons after 2 seconds?
2. half life= .7Tm, mean life=RC
3. I put the R and C values into get the mean life and got an answer of 7 seconds, and than to find the halflife, I multiplied the mean life by .7 and got 10 seconds. I just don't know where to go from there though. I know the answer is 820, but I don't know how to get that answer. Is there a formula where I can put in the number of seconds using the mean life and half life to get the answer?
Use the equation
Q = CV
andrevdh said:
Use the equation
Q = CV
I tried using that formula but what do I insert for V? I put in 2 seconds and it didnt work, i tried working backwards, that didnt work either...what am i doing wrong?
V is voltage. Relate voltage to current and then Charge to current, you'll get a differential equation.
The capacitor start out with a charge of
1.60 \times 10^{-16}\ C
this means that the initial voltage over the cap will be
V_o = \frac{1.60 \times 10^{-16}}{C}
or rather... the RC discharge equation of the cap
V = V_o e^{-\frac{t}{\tau}}
can be rewritten for the decay of the charge on the cap using the relation
Q = CV
