Calculating refractive index using lens
The discussion centers on calculating the refractive index of liquids using a converging lens and mirror, noting that the refractive index of water is lower than that of glass. It raises the question of whether the same method can be applied to a liquid like mercury, which has a higher refractive index than glass, but concludes that this may not work due to ray divergence preventing the formation of a real image. Participants express uncertainty about the applicability of the "standard method" for liquids with higher refractive indices than glass. Various methods exist for measuring refractive indices, applicable to both higher and lower indices compared to glass. The conversation highlights the complexity of measuring refractive indices in different media.
m~ray
we can calculate the refractive index of liquids like water using a converging lens and mirror by the standard method . r.index of water is less than that of lens(glass) . now taking mercury, whose r.index is > glass, can we do the same experiment and find its r.index ?
i believe the answer is no.. coz there the rays get diverged and hence no real image is formed. but i don't think it will always diverge ?? any in sight ?
Science news on Phys.org
Refractive index of mercury? It seems to be too opaque to have well defined refractive index (at least if you take r.i. in its classical meaning).
oh ya.. mercury is a bad example.. let's say any other transparent liquid having r index > that of glass.
So now I have no idea what do you mean by "standard method".
There are lots of methods to measure R.I. which may be used for liquids of both higher and lower R.I. than the one of glass.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
Thread 'How to model converging illumination through object plane (in ZEMAX)'
Hello community, I'm designing a projection lens system for a 35mm film projector in Zemax OpticStudio and struggling with the correct sequential mode setup for the illumination geometry. The light source is a Xenon short-arc lamp reflected by an ellipsoid mirror, which creates a converging cone with a 40.6 degree full angle that passes through the film gate. The film gate is my object plane, but the light doesn't diverge from it like a typical Lambertian source. Instead, the converging...
