Calculating Rocket Force with Mass, Velocity, and Time | Quick Question
  • Thread starter Thread starter Flinthill84
    Force
To calculate the force exerted on a rocket at takeoff, the propelling gases are expelled at a rate of 1500 kg/s with a speed of 4*10^4 m/s. The discussion emphasizes using a one-second interval for time to simplify calculations, allowing for the application of the formula F = Δp/Δt. The force exerted by the gas on the rocket is equal to the force the rocket exerts on the gas. Participants confirm that finding the acceleration of the gas and applying F_net = ma is the correct approach. The conversation concludes with a participant expressing confusion and retracting their earlier statements.
Flinthill84
Here is the problem:
Calculate the force exerted on a rocket, given that the propelling gases are expelled at a rate of 1500kg/s with a speed of 4*10^4 m/s (at the moment of take off)
I know that force is equal to the mass times the change in velocity over the change in time. Can I use a one second interval for the time and just make up a time like that?
Yes, you are on the right track. The gas exerts the same force on the rocket as the rocket exerts on the gas. Find the acceleration of the gas by setting time equal to one second, and displacement equal to 4\times10^{4} meters. Then use F_{net}=ma.
Solving for acceleration won't the acceleration be the same as the velocity in this equation?? I used the formula of Vf=Vo+at
Use:
\vec F = \frac{\delta \vec p}{\delta t}
In this case:
\frac{\delta p}{\delta t} = v \frac{\delta m}{\delta t}
Where \frac{\delta m}{\delta t} = 1500 kg/sec[/tex]<br /> <br /> AM
Thankyou very much!
Oh boy...forget this post. Not sure what I was thinking here... :eek:
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
