Calculating Scale Readings for Dropped Mass on a Spring
  • Thread starter Thread starter Leomar
    Mass Spring
The discussion centers on calculating the scale readings when a mass is dropped onto a spring. For scenario (a), the spring compression is determined using the equation 1/2kx² = mbgx, resulting in x = 2mbg/k, leading to a scale reading of F = mpg + 2mbg. In scenario (b), the additional height h introduces extra potential energy, requiring the equation 1/2kx'² = mbg(x' + h) to find the new compression x', resulting in F = mpg + 2mbg(1 + hk/2mbg)^(1/2). The participants clarify the distinction between x and x' and confirm the work done by the spring differs in both scenarios.
  • Understanding of Hooke's Law and spring mechanics
  • Familiarity with potential energy concepts in physics
  • Knowledge of energy conservation principles
  • Basic algebra for solving equations involving variables
  • Study the principles of energy conservation in mechanical systems
  • Learn about the applications of Hooke's Law in real-world scenarios
  • Explore advanced topics in dynamics involving springs and mass
  • Investigate the effects of varying mass and height on spring compression
Physics students, educators, and anyone interested in understanding the dynamics of spring systems and energy transfer in mechanical contexts.
Leomar
Hi, hope you can help me with finding out what I am doing wrong on this problem.
It goes as follows:
A massless, vertical spring of force konstant k is attached at the bottom to a platform of mass mp, and at the top to a massless cup.
The platform rests on a scale. A ball of mass mb is dropped into the cup fro a negligible height. What is the reading on the scale a) when the ball momentarily comes to a rest with the spring compressed.
And b) same as a), but with the ball dropped from a height h.
For problem a), I set that the ball would have potentional energy=0 when at rest, and thus that the work done by the spring must equal mbgx.
1/2kx^2=mbgx
x=2mbg/k
Using Hookes law, the force exerted by the spring on the ball is 2mbg.
So the spring exerts the same force on the platform, and the scale should show F=mpg+2mbg
Which according to the solutionsguide is correct. (Though I might have made a mistake here anyway)
For problem b), I tried using the same method, setting that
1/2kx^2=mbg(x´+h) (Where x`=2mbg/k, from problem a))
x=(2mbg(2mbg/k+h)/k)^(1/2)
rearranging
x=2mbg/k(1+hk/2mbg)^(1/2)
Which gives the solution
F=mpg+2mbg(1+hk/2mbg)^(1/2)
This is where the solutionsguide is disagreeing with me. :smile:
A hint or two would be very much appreciated.
Thanks for posting your work, leomar. It makes it easier to give an answer.
x is different from x'
x is the compression when the ball is just placed in the cup.
When the ball is then dropped from a height h above the cup before striking it, then it has additional energy which compresss the spring further and so x' > x.
I realize that the the x in a) and the x in b) are different values, but I did think that the different amount of work needed to be done by the spring would be equal to mgh. Where h is the extra height.
I might have been confusing by using x in equation a), then in be referring to it, but with a different name, sorry about that.
But it really boils down to, am I doing anything wrong in assuming that the work done by the spring in situation b), 1/2kx^2, equals to the work done in situation a), mbgx' (Note that this x' is the length the spring was compressed in a), not how much it will be compresses in b)) plus the extra energy gained from the heigh h, which would equal mbgh.
1/2kx^2=mbg(x´+h)
Hope that clears it up.
The work done is different in either case.
The WD in b) is greater than the WD in a) because the spring is comprressed more in case b).
For a) WD = (1/2)kx² = mgx
For b) WD = (1/2)kx'² = mg(x' + h)
To find the new force on the scale, find F = mpg + kx'
You seem to have been be using x for part a),
1/2kx^2=mbgx
x=2mbg/k
In my explanation above, I have used x as the compression for part a) and x' as the compression for part b).
Ah, now I see, thank you very much for you help.
Should be able to figure it out now :smile:
Edit: Yep, that did it. Again, thanks.
  • · Replies 58 ·
