Calculating Slide Distance on an Inclined Surface with Friction
  • Thread starter Thread starter vysis
    Incline
The discussion revolves around a physics problem involving a skier on an inclined slope, where the goal is to determine the distance the skier will slide before coming to a stop. The scenario includes parameters such as the angle of inclination, initial speed, and coefficient of friction.
  • Participants explore the components of gravitational force acting on the skier and the retarding force due to friction. There is a focus on understanding how to calculate the rate of deceleration without the mass of the skier being provided.
Some participants have offered guidance on how to approach the problem by suggesting that the mass may not be necessary for calculating the net force and deceleration. The discussion reflects a mix of attempts to clarify the problem and explore different interpretations of the given information.
There is an acknowledgment that the problem does not provide the mass of the skier, which raises questions about how to proceed with the calculations. Participants are considering the implications of this missing information on their approach to the problem.
vysis
A skier on a slope inclined at 4.7 degrees from the horizontal starts down the slope with an initial speed of 2.7m/s. The coefficient of friction is 0.11. Determine how far the skier will slide before coming to a rest.
Fnet=ma
F(f) = (mu)N
Completely lost =(
Fnet=ma
F(f) = (mu)N
Completely lost =(
What is the component of gravitational force on the skier that would induce the skier to continue down hill? What is the retarding force?. Using that find the rate of deceleration. That might be a good place to start then.
thats the thing though... it doesn't give you the mass. It ONLY gives you the force of kinetic friction and the initial speed
Solved, thanks guys
Don't despair. Work things through. The mass may not matter.
When you develop the equation for the net force the mass part drops out to give you the net retarding deceleration.
You use that with the distance relationship that is v2/2a
Edit: Congrats then. Good Luck.
  • · Replies 19 ·
