Calculating Student Power: P=W/T Equation Explained | 60kg Lift in 4 Seconds"
  • Thread starter Thread starter dois
    Power
The discussion revolves around calculating the power exerted by a student lifting a 60kg weight to a height of 2.5 meters in 4 seconds, utilizing the equation P=W/T.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster expresses uncertainty about using the P=W/T equation, noting that work is an unknown variable. Participants discuss the force due to gravity and its role in calculating work and power.
Participants are exploring the relationship between force, work, and power, with some providing clarifications on the calculation of gravitational force. There is an ongoing examination of the assumptions related to gravitational force and its implications for the problem.
There is a mention of the gravitational constant and its variability depending on the planetary context, which may influence the calculations.
dois
How powerful is a student who can lift 60kg from the floor to above their head (2.5 meters from the ground) in 4 seconds?
To find power we would use the equation
P= W/T
I'm not sure if we would use the P=w/t equation, and work is an unknown variable, and when I try to find W, W=FxD, Force is also an unknown variable
What is the force on the object due to gravity (this would also be the force required to lift it)?
Would the force on the object due to gravity be 9.8N
so the Force required to lift it is 9.8 N
Force due to gravity is mg. Then use that and the distance to find the work, and the work and the time to find the power.
Keep in mind that the force by gravity is not 9.8 N but rather m(9.8 m/s^2) where 9.8 = g. This would be different if we were on a planet other than our homely earth.
  • · Replies 20 ·
