Calculating the charge distribution on the surface of an assymetric conductor
The discussion revolves around calculating the charge distribution on the surface of an asymmetric closed conducting surface. Participants explore the relationship between surface charge density and the electric field, given a net charge and the geometric equation of the conductor.
  • Participants discuss the need for approximations and numerical methods to establish the electric field and surface charge distribution. Questions arise about the interdependence of electric field and charge density, as well as the implications of the uniqueness theorem for charge distribution.
Guidance has been offered regarding the use of numerical methods and the importance of boundary conditions in solving Laplace's equation. Multiple interpretations of the problem are being explored, particularly concerning the relationship between potential and charge density.
Participants note constraints such as the lack of specific information about the charge distribution and the challenges posed by the geometry of the conductor. Assumptions about the behavior of electric fields and potentials in relation to conductors are also under discussion.
Chitran
How do I calculate the charge distribution on the surface of any asymmetric closed conducting surface? Is it possible for me to calculate the surface charge density 'σ' as a function of '[itex]\bar{r}[/itex]' the position vector in a spherical co-ordinate system in space, provided I know that the conductor has been qiven a net charge 'Q' and the equation of the conductor in space is ((x/a)^2)+((y/b)^2)+((z/c)^2)=1...
For any conducting surface you will have to resort to an approximation.
In brief: use a numerical method to establish the Electric field for the system. Use that E field result to establish surface charge distribution.
But how do I calculate [itex]\bar{E}[/itex] if I don't know my σ? It's like the chicken egg problem except that it's not what comes first that matters, but I need one to know the other. All I know unfortunately is the shape of the conductor and the total charge Q which according to the uniqueness theorum has a unique way of settling on the surface in the abscence of any external electric field...
you don't need to know anything about the charge. Field lines are normal to a conducting surface and themselves normal to equipotentials. This means that you can set up a grid with random starting values for potential and by recalculating each value in turn end up closer to the correct solution.
a quick google gave this http://www.physics.hku.hk/~phys3231/pdf/P1%20-%20Static%20Electric%20Field%20-%20Laplaces%20equation%20in%202D.pdf The 3d process is very similar.
Also http://www.ece.msstate.edu/~donohoe/ece3323analytical_numerical_techniques.pdf you need the last few pages.
The procedure looks hard but really isn't: Though it is a long time since I last did one!
Just solve Laplace's equation for the potential. You know that the potential on the surface is a constant (which you may as well set to zero) and that the potential at large distances should look like that of a point charge, so you have your 2 boundary conditions. From the potential, you can determine the charge density.
  • · Replies 17 ·
