Calculating the force on a shaft
  • Thread starter Thread starter Blad9
    Force Shaft
To calculate the axial and radial forces on a shaft with a 10 kg plate and an additional 37.5 kg load, the axial force was determined to be 153 N and the radial moment was calculated as 191 Nm. However, the discussion highlights the need for a free body diagram (FBD) that includes the bearings and their forces, which are crucial for accurate calculations. There is also a suggestion to use symbolic names for dimensions instead of numerical values to clarify the source of each measurement. Additionally, the absence of reaction forces on the upright arm in the FBD raises questions about the completeness of the analysis. Overall, the calculations may need to be revisited for accuracy and clarity.
Blad9
I would like to attach bearings on a shaft, see: https://www.physicsforums.com/showthread.php?p=3856547#post3856547
Therefore I would like to calculate the axial and radial force on the shaft, so I can select the right bearings.
The picture looks a as following: http://i39.tinypic.com/kd1naq.jpg
So I have a shaft, with a plate attached on it with a weight of 10kg. A load will be putted on the plate wit a weight of 37,5kg. Now I would like to calculate the axial and radial force on the shaft.
Sketch:
http://i41.tinypic.com/kd1iqx.jpg
Sum Fx to A = o
Fxa = o
Sum Fy to A = o
(-375N x 0,625 x 0,3125) – (100 x (0,725/2)) + Fya x 0,725 = 0
-73,2 - 37,6 + Fya x 0,725 = 0
-110,8 + Fya x 0,725 = 0
Fya = 110,8 / 0.725
Fya = 153N
Som M t.o.v. A = o
M in a = 375 x (0,725 – 0,3125) + 100 x 0,3625
M in a = (375 x 0,4125) + 36,25
M in a = 191Nm
The shaft would have an axial force of F = 153 N and radial momentus of M = 191 Nm according to this calcuation.
Does this look ok, or should I calculate it completely differently?
[/quote]
You need to go back and shows the bearings in your FBD, and include their forces in your force and moment sums.
Also, it is not entirely clear where some of your dimensions came from; can you identify them, please?
What dimensions are not identified? Do you see the picture?
Yes, I saw the picture. One of the difficulties is that you have worked entirely with numerical values, rather than giving symbolic names to each of your dimensions. If you gave each of them a symbol, before plugging in the number, then it would be much easier to see where each item came from.
Also, in the FBD, I do not see any reaction forces on the upright arm; why?
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
