Calculating the Frequency of a Car Horn Using the Doppler Effect
Two cars with identical horns produce a beat frequency of 5.8 Hz when one is stationary and the other is moving toward an observer at 13 m/s. The discussion centers on using the Doppler effect to calculate the frequency emitted by the horns. The relationship between the beat frequency and the frequency difference due to the Doppler shift is crucial for determining the actual frequency of the sound. By applying the Doppler shift equation and the beat frequency formula, the correct frequency can be derived. The participant successfully applied this knowledge, achieving a perfect score on their final exam.
Morgan89
Two automobiles are equipped with the same single-frequency horn. When one is at rest and the other is moving toward an observer at 13 m/s, a beat frequency of 5.8 Hz is heard. What is the frequency the horns emit? Assume T = 20°C.
I understand that this is related somehow to the doplar effect. I thought to use the equation to find the heard velocity when a sound is moving towards a listener which is...
Frequency Heard = Frequency Sound (Velocity of Sound/(Velocity of sound- velocity of moving sound)
This formula should work, but i am wondering if i can assume beat frequency is the actual frequency of the sound. I feel as though it is not. I need to know how to use this beat frequency to find the actual frequency of the sound. HELP!
How is the beat frequency related to the difference of the frequencies (caused by the doppler shift) of the horns? This will allow you to find the difference in frequency caused by the Doppler shift and therefore the frequency the horns emit.
So if i say the frequency heard of the moving car is F of sound * (v/v-velocity of moving car) then i can just say that the difference between that value and the regular f of sound equals the 5.8 beat frequency right?
Yep, that's right:
f_{beat}=|f_{2}-f_{1}|
And you know f_{2} in terms of f_{1} from the doppler shift equation; so put it all together, and you should get the right answer!
I got It! 100 on my Final! Whooo Hooo! I love you all!
Congrats, and well done! :biggrin:
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
