Calculating the hydrodynamic entry length of a cicular pipe.
The discussion focuses on calculating the hydrodynamic entry length for laminar incompressible flow in a circular pipe, specifically seeking a method to derive the entry length as a function of Reynolds number and pipe diameter. Participants mention that various formulas exist, typically yielding a ratio of entry length to diameter and Reynolds number between 0.02 and 0.06. The original analytical solution by Boussinesq from 1892 is referenced, but the literature lacks detailed derivations, providing only final expressions like X_entry length = 0.05*Reynolds*Diameter. There is a consensus that while analytic solutions are possible, they involve complex mathematics that can be challenging to navigate. The request for assistance in deriving the entry length for 2D channel flow remains open.
wildturkey101
Does anyone know how to calculate the entry region length of laminar incompressible flow in a pipe? There are several formulae available which give a ratio of the (entry length)/(pipe diameter)/(Reynolds number) = 0.02-0.06.
I'm not looking for the final solution, but rather the approach used in order to calculate the entry region as a function of Reynolds number and pipe diameter, and so far have been unsuccessful.
It's a classic problem originally handled by Boussinesq, but I can't seem to find any literature sources that actually go through the derivation. All the fluids books I've looked at just give the final expression:
Any help?
I don't think you're going to find a derivation for that. IIRC those are correlations from a lot of experimentation.
Analytic solutions are possible, but I've just been bogged down in the mathematics...
Boussinesq first solved it analytically back in 1892 to give the classic approximation for laminar flow of (X/D)/Re=(1/20) ... No one seems so keep 19th century French fluid mechanic journals on file anymore. ;)
I'm looking for the same solution for 2D channel flow. Can someone help me? I need the derivation
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
