Calculating the required fan size and cfm.
  • Thread starter Thread starter Uridan
    Cfm Fan
To calculate the required fan size and CFM for a vertical wind tunnel, the cross-sectional area and desired wind velocity of 10 m/s must be considered. The dimensions of the tunnel (upper diameter 26 cm, mid diameter 22 cm, lower diameter 18 cm, and height 50 cm) are essential for determining airflow. Given the high velocity needed, a centrifugal fan may be more suitable than an axial fan due to pressure requirements. It's important to refer to fan curves to understand the performance of different fan models. Accurate calculations will ensure that multiple fans can compensate for any failures, maintaining the ball's height effectively.
Uridan
hi,
I am an electronic engineer student and I am doing a study on control systems that can be used to control a ball's height in a vertical wind tunnel.
I have a problem in calculating the fans needed (as in size and number of blades) and the amount of cfm that the fans need to produce. The wind tunnel specs are:
Upper diameter: 26cm
mid diameter: 22 cm
lower diameter: 18cm
Tunnel height: 50cm
the ball that needs to be lifted requires 10m/s winds for terminal velocity.
I don't know that much about flow rates and fluid mechanics that is why I am asking :shy:.
My plan is to make a number of fans at the top of the wind tunnel so if one of the fans fail, the other fans will compensate to keep the ball at the pre set height.
Thanks, any help would be appreciated :)
Regards
Uridan
Welcome to PF.
If you have the dimensions (how big is the ball, though, and where will you be holding it?) and the required velocity, you can calculate the flow rate with simple geometry (cross sectional area times velocity). Obviously, you have some units to convert...
For fan selection, you have a fair amount of velocity there, which means a fair amount of pressure so I'm not sure an axial (bladed) fan will do. You may need a centrifugal fan. Once you have the airflow, though, start looking for fan curves of available fans and you'll start to get an idea of how real fans perform.
