Calculating the size of a capacitor in a sample and hold circuit
  • Context: Engineering
  • Thread starter Thread starter CoolDude420
    Capacitor Circuit
The discussion focuses on calculating the size of a capacitor in a sample and hold circuit, specifically addressing the relationship between signal-to-noise ratio (SNR), jitter power, and thermal noise power. The SNR is given as 60dB, which translates to a power ratio of 1000. The participant initially encounters a negative thermal noise power value, which is identified as a simple mathematical error. The correct approach involves using the equation SNR = Psignal/(Pjitter + PthermalNoise) to derive the capacitor size from the thermal noise power, equated to kT/C.
  • Understanding of signal-to-noise ratio (SNR) calculations
  • Familiarity with thermal noise equations, specifically kT/C
  • Basic knowledge of jitter power in electronic circuits
  • Proficiency in mathematical operations and error checking
  • Research the derivation of thermal noise power in electronic circuits
  • Learn about the implications of SNR in analog signal processing
  • Study the effects of jitter on signal integrity in sample and hold circuits
  • Explore capacitor sizing techniques based on noise analysis
Electrical engineers, circuit designers, and students studying analog electronics who are involved in designing sample and hold circuits and optimizing performance through noise analysis.
CoolDude420
In sampling system the sample rate is 500 Ms/s with an input signal of range of 1 V
peak−peak and a clock jitter of 1 ps rms . A performance of 60 dB is required for all
signals the Nyquist baseband. Calculate its size of the capacitor.
Analog-to-Digital Conversion by Marcel Pelgrom Book
First, I calculate the jitter power with an equation given in the book
Next, I calculate the signal power
Now, I know that SNR = Psignal/(Pjitter + PthermalNoise),
However, I seem to be getting a negative value for the thermal noise power?? My plan was to use this thermal noise power and equate it to kT/C to get my capacitor size. But the thermal power is negative??
What am I doing wrong?
the thermal power is negative?? What do you calculate for the SNR?
your SNR is stated as 60dB, so the factor 10^(60/20) yields 1000 fold power ratio, so your scaled Pjitter is around 0.0003
0.125 - 0.0003 is positive not negative simple math mistake?
  • · Replies 22 ·
