Calculating the Slitwidth of a Diffraction Gradient
The discussion focuses on calculating the slit width of a diffraction grating based on a given experimental setup involving laser light and a screen. Key parameters include the distance to the screen (2.95 m), wavelength of light (620 nm), and the distance between the central maximum and the first-order bright fringe (1.6 cm). The user initially struggles with the calculations, particularly in determining the distance to the first dark fringe, which is clarified to be half of the distance to the first bright spot (0.8 cm). Confusion arises regarding the use of sine and tangent functions in the equations, but the user ultimately resolves the issue. The conversation highlights the importance of precise calculations and understanding the relationships between angles and distances in diffraction problems.
bmb2009
A set of narrow vertical slits is located a distance D from a screen. The slits are equally spaced and have the same width. The intensity pattern in the figure is observed when light from a laser passes through the slits, illuminating them uniformly. The screen is perpendicular to the direction of the light. Data: Distance to the screen = 2.95 m, Wavelength of light = 620 nm, distance between the central maximum and first order bright fringe is 1.6 cm. Distance between slits is 1.166E-4 m and number of slits is 3.
I've tried a lot of things and it seems that I need to know the distance between the central maximum and the first order minimum (the first dark fringe). The equations i thought were relevant were sinθ = λ/a where λ is wavelength and a is slit width, and tanθ= y/L where y is the distance from the central mxaimum to the first dark fringe and L is the distance to the screen. So i figured i need to solve for the angle with the second equation and then plug that into solve for the slit width but it doesn't seem to work. What am I doing wrong?
Thanks in advance!
It would be nice to know what the question is.
That should be half of the distance between the central max and the first bright spot, 0.8 cm.
There is a lot of confusion between L and the perpendicular distance to the screen, but it usually doesn't matter. However, it should certainly be sin θ = y/L or else tan θ = y/2.95. Hard to say what went wrong in your calc when you don't show it. Note that any rounding of θ will strongly affect the value for a.
sorry i just realized some of the question didn't copy over... but i ended up figuring it out.. Thank you anyway!
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
