Calculating the Speed of a Ball Rolling Down a Hill
The discussion revolves around calculating the speed of a ball rolling down a hill, specifically comparing a solid sphere and a cube under the influence of gravity. Participants explore the effects of rotational motion and energy conservation in this context, with a focus on theoretical calculations and assumptions regarding friction.
  • Some participants argue that a cube should slide down a hill faster than a sphere due to the sphere's rotational energy taking away from its translational speed.
  • Others point out that without friction, a sphere cannot roll, which raises questions about the assumptions made regarding friction in the problem.
  • One participant suggests that if there is static friction, the potential energy from gravity can be converted into both translational and rotational kinetic energy.
  • Another participant provides a formula for the velocity of the sphere as it rolls down the hill, indicating the relationship between height and speed.
  • Some participants discuss the moment of inertia of the sphere and how it affects the calculations, with one suggesting that the moment of inertia should be used instead of angular momentum in the energy equations.
  • Several participants arrive at similar results for the time taken to reach the bottom of the hill, though they use different methods to derive their answers.
  • There is a discussion about the applicability of kinematic equations, with some participants questioning their validity in this context due to the nature of the motion involved.
Participants generally agree on the relationship between potential energy and kinetic energy but disagree on the implications of friction and the methods used to calculate the time taken for the sphere to roll down the hill. Multiple competing views on the assumptions regarding friction and the application of kinematic equations remain unresolved.
Participants express uncertainty about the assumptions made regarding friction, particularly the distinction between static and kinetic friction. There are also unresolved mathematical steps related to the derivation of equations and their applicability to the problem.
This discussion may be useful for students and enthusiasts interested in classical mechanics, particularly those exploring the dynamics of rolling objects and energy conservation principles.
tummbacoco
So I know that given a unchanging hill, and same mass between a sphere and cube, that the cube should slide down the hill faster (assuming negligible friction). This is observed through the energy "lost" by the sphere which instead of having all of its potential energy transferred towards rolling down the hill, some goes to giving the ball rotation. Now I was wondering if there is anyway to calculate of how fast a ball would roll down a hill, only given gravity.
For example, a solid sphere (weighing 1kg with a radius of 1m) is on top of a hill that is 15m high with an slope of 30 degrees. How long will it take for the sphere to reach the bottom. Since this is an example problem an explanation is more helpful than an answer. Thanks!
You've made contradictory assumptions about friction for the sphere and cube(the sphere can't roll unless there is friction). Do you really want to do that?
If there is no friction the ball will not rotate either. However, a similar problem involves homogeneous balls and cylinders rolling without slipping vs hollow balls and cylinders doing the same. They have different moments of inertia and will therefore experience different accelerations, see this image from Wikipedia:
Edit: Note that the red sphere is the hollow sphere...
You should realize that without friction, rolling does not originate.
So, let's assume enough friction to have 'no slipping'. In that case potential energy from gravity is converted to kinetic energy -- a part as translational and one part as rotational.
Do you know about angular velocity and rotational kinetic energy ?
Yea I'm familiar with them, and my problem was that I could calculate the amount of energy that went towards rotational kinetic energy. PE=1/2mv^2 + 1/2Lw^2 , and this makes sense when compared to a cube that isn't rotating so would have PE=1/2mv^2 . So my question is how slower would the ball accelerate compared to the cube? I could find out how fast the cube would slide down by finding gravity's component vector pushing it and integrate, but I can't do the same for the sphere because some energy goes towards rotating the sphere. Thats where I'm stuck
I'm new here and didn't really know how to word the question. It is assuming that there is static friction but that there is no kinetic friction.
I'm assuming you meant to write I for moment of inertia and not L for angular momentum.
If you first find the moment of inertia of a sphere, which you could find through easy-ish calculus or just look up, you could use conservation of energy to find the final velocity quite easily. Remember that there's a simple relation between angular and linear velocity.
You could say there's static friction but not kinetic friction, or you could just say the kinetic friction is small enough for it to be considered negligible.
Yes, you can answer it, but I guess you'd need calculus... If you don't know calculus just skip to the "which gives us:" part in the end.
This is how I went through it:
Through conservation of energy we know that:
Pe = KE_T + KE_R
At every point, so:
mgh = \frac{mv^2}{2} + \frac{Iω^2}{2}
I_{Sphere} = \frac{2}{5} mr^2
and
ω=\frac{v}{r}
So
mgh = \frac{mv^2}{2} + \frac{mv^2}{5}
giving us the velocity of the sphere at each height covered:
v(h)=\sqrt{\frac{10}{7}gh}
If it is a simple slope, you can parametrize the length s of the ramp in terms of the height:
\frac{h}{Sin(θ)}=s
Since:
v(h) = \frac{ds}{dt}=\frac{ds}{dh}\frac{dh}{dt} = Csc(θ)\frac{dh}{dt}
So:
dt = Csc(θ)\frac{dh}{v(h)}
\int_{0}^{t}dt' = Csc(θ)\int_{h_f}^{h_0}\frac{dh}{v(h)} (Switched limits of h's because its going downwards)
\int_{0}^{t}dt' = Csc(θ)\int_{h_f}^{h_0}\frac{dh}{\sqrt{\frac{10}{7}gh}}
which gives us:
t(h,θ) = Csc(θ)\sqrt{\frac{14}{5 g}}(\sqrt{h_0}-\sqrt{h_f})
So, in your case, we'd get:
t(15,30°) = Csc(30°)\sqrt{\frac{14}{5\times9.81}}(\sqrt{15}-\sqrt{0})=4.13828s
Which is considerably slower then a block sliding down the same ramp, which would take 2.4731s
PS: This has got to be one of the pretties solutions I've ever came up without of the blue, kind of proud of myself :biggrin:
Well, I used a different method, but we got the same result.
We found that ##v= \sqrt { \frac {10gh} {7}}## using the same method.
I then used two kinematic equations to solve for time:
##v^2_f=v^2_i+2ad⇒a=\frac {v^2_f} {2d}##
##v_f=v_i+at⇒t=\frac {2d} {v_f}##
Plugging in the final velocity and then plugging in the values gave me 4.318 seconds as well.
We both agree that ##v= \sqrt { \frac {10gh} {7}}##
Unfortunately I don't think doing like that works, since v is the total speed, not just the speed in the y direction, so it won't work by just plugging in the formula, since the formula only works for one dimension at a time.
Also, it's got to be dependent on the angle of the ramp, since going down 15m on a steep slope is much faster then in a shallow slope, and an angle of 0 would give back an infinite time (since there'd be no slope).
abilolado said:
Unfortunately I don't think doing like that works, since vvv is the total speed, not just the speed in the y direction, so it won't work by just plugging in the formula, since the formula only works for one dimension at a time.
The equation works as long as the acceleration is constant. If I know the initial velocity, the final velocity, and the displacement, and I know the acceleration is constant, I can find the acceleration; it doesn't matter what direction it's in.
The equation I derived is dependent on distance the ball travels and height of the ramp, so therefore the angle.
You're right! My bad.
Damn, all that calculus for nothing
and now I realize
Csc(θ) \sqrt{\frac{14}{5g}}(\sqrt{h})
\frac{s}{h}\sqrt{\frac{14}{5g}}(\sqrt{h})
s\sqrt{\frac{14}{5gh}}
2s\sqrt{\frac{14}{20gh}}
2s\sqrt{\frac{7}{10gh}}
\frac{2s}{\sqrt{\frac{10gh}{7}}}
Exact same thing... damn...
Well, at least it was fun deriving the whole thing :biggrin:
If you take into account the work required to derive the equations I used, our methods are probably about as fast.
I still have to often avoid using calculus because I've yet to receive a formal education on it (I have to wait until next year for that).
  • · Replies 32 ·
16K
