Calculating time from two voltages
  • Thread starter Thread starter Spreco
    Time
The discussion revolves around calculating the time when two voltages, u1 and u2, are equal, given their equations. The phase difference was determined to be 90 degrees, and the solution in the textbook states this occurs at 3.16 ms. The user initially struggled with isolating 't' from the sine function in the equation 50 sin(314t + ∏/3) = 100 sin(314t - ∏/6). After guidance, they successfully transformed the sine functions into a solvable format and found the time values. Ultimately, the user expressed gratitude for the assistance received in solving the problem.
Spreco
I've gotten this for homework from my Electrotechnics class
You are given two voltages: u1=50 sin(314t + ∏/3) and u2=100 sin(314t - ∏/6). You need to calculate the phase difference (pretty easy, already did that it's 90 degrees) and time when the two voltages have the same value. The solution in the book says 3,16ms.
General formula for calculating the voltage is u = Um sin(ωt +- θ).
So, because it says that I need to find the time both voltages are the same value, u1 must be equal to u2. So, u1=u2 50 sin(314t + ∏/3)=100 sin(314t - ∏/6). Now the problem is how do I get the 't' out of the sine and aren't they going to cancel each other out because they're same?
Please ask me anything else you need to solve this problem. THank you.
Hi Spreco! Welcome to PF!
What cancels what? You have 50 sin(314t + ∏/3)=100 sin(314t - ∏/6) or sin(314t + ∏/3)=2sin(314t - ∏/6). You cannot solve this or is it something else that troubles you?
Hi Spreco
Welcome to Physicsforums!
Rewrite u1=50 sin(314t + ∏/3) such that instead of sine ,you get a cosine .I mean convert sine into cosine.
What do you get ?
Hi Spreco, do this: u1=u2, 50 sin(314t + ∏/3)=100 sin(314t - ∏/6) => sin(Pi t + Pi/3)=2 sin(Pi t - Pi/6),
sin(a+b) = sin a cos b + cos a sin b, then:
sin(Pi t) cos(Pi/3) + cos(Pi t) sin(Pi/3) = 2 sin(Pi t) cos(Pi/6) - 2 cos(Pi t) sin(Pi/6)
sin(Pi t)= a, cos(Pi t)= b,
sqrt(3) / 2 a + 1/2 b = sqrt(3) a - b
-1/2 a = 3/2 b
-a = 3 b
sin x = -3 cos x, now specify any value of cos x s.t. 3 cos x<1, which means cos x< 1/3, -70.5< x < 70.5°, or 109< x <251 and then the equation has a solution. In particular you find the values of t from x= 180 * t. The
The task was to find the time, and after some thinking and ideas I solved it and got the solution. Thanks for all the help and ideas you gave me.
http://i.imgur.com/EwR4GOp.jpg (The picture is high resolution, you can zoom in really close to see the details)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
