Calculating Toboggan Acceleration and Tension with Newton's Laws
  • Thread starter Thread starter whatwhat11
    Laws Newton's laws
Two toboggans connected by a rope experience a force of 250N, resulting in an acceleration of 2.5 m/s² and a tension of 100N in the rope. When a third toboggan is added, the new acceleration of the system is 2 m/s², with the force exerted by the first toboggan on the second being 130N and the force from the second to the third being 50N. Introducing a coefficient of kinetic friction of 0.10 changes the acceleration to 1.02 m/s², but the tension values for the connections remain the same as before. The discussion emphasizes the importance of calculating net forces and friction to determine tensions accurately.
whatwhat11
Two toboggans are connected by a rope. The first toboggan has a mas of 60 kg and the second has a mass of 40 kg. The two toboggans are pulled by a rope connected to the first toboggan. If the force exerted on the rope is 250N [E], and friction between the toboggans and the ice and be ignored, find:
(a) the acceleration of the toboggans.
(b) the tension in the rope connecting the toboggans
I found the acceleration to be 2.5m/s^2 and the tension in the rope to be 100N
Question 2 it asks, suppose a third toboggan of mas 25kg is connected tot he second toboggan in question 1. Find:
(a) the acceleration of the system of three toboggans.
(b) the force exerted by toggan one on toboggan two.
(c) the force exerted by the second toboggan on the last one.
I got 2m/s^2 for (a), 130N[E] for b and 50N[E] for c
But what I don't get is when it asks me to repeat question 2 with the coefficient of kinetic friction being 0.10.
I only found the acceleration being 1.02m/s^2. How can I find (b) and (c)?
I know I'm not helping but how did you find 2b?
i added the masses of the 40kg and 25kg toboggan then found FNet.
Fnet =ma
Fnet = (65)(2)
Fnet= 130N
welcome to pf!
hi whatwhat11! welcome to pf! :smile:
(try using the X2 button just above the Reply box :wink:)
same method
start with (c) …
you know the acceleration a, you know the friction force F, so the tension T is … ? :smile:
same method
start with (c) …
The acceleration is 1.02 and the friction force for all of the toboggans is 122.5N. The answer key says that (b) has to equal 130N again and (c) has to equal 50N again.
For (c) I did Fg=mg
Fg = (25)(-9.8)
Fg = -245N
so the Ff=(0.10)(245)
Ff= 24.5N I am not sure what to do next ;/
whatwhat11 said:
… so the Ff=(0.10)(245)
Ff= 24.5N
ok, so T - 24.5 = mass times acceleration :wink:
(try using the X2 button just above the Reply box :wink:)same method
start with (c) …
So (1.02)(25) = 25.5
-24.5 - 25.5 = -50N Right?
(most people would have made those all pluses :rolleyes:, but …)
yes :smile:
Thank you :D
