Calculating Variance of Eq. with random variables
shakystew
I am attempting to calculate a heat transfer across a medium with known material properties. I have the equation and all but one variable I have an exact answer for. I require the variance of my answer.
I know ALL variables (ie numerical value) except the the last h. So far, using some engineering parameters for the problem, I have estimated the value by taking 10% perturbations of the normal value of h (that is, the value is usually ~3.0 for this problem, and I have used logic to say that with the additional medium, the value will only affect AT GREATEST +/- 10%).
I am unsure on how to actually calculate the value now. I have ran the equation in MATLAB using random number generator from 2.7-3.3 (10% perturbations) with 1E9 histories. Can I use this value to get the variance? (The output is not normal/gaussian).
Thanks in advance!
Assuming everything except ##h## is constant, the variance is simply
$$\text{var}\Delta T = \left(\frac{q'}{2\pi R_{00}}\right)^2 \text{var}\left(\frac{1}{h}\right)$$
This follows from the following basic property of variance: if ##x## is a random variable and ##a## and ##b## are constants, then ##\text{var}(a(x+b)) = a^2 \text{var}(x)##. In other words, the constant offset ##b## does not affect the variance, and the multiplicative scale factor ##a## multiplies the variance by ##a^2##.
There is no general property relating ##\text{var}(1/h)## to ##\text{var}(h)##. How they relate depends on how ##h## is distributed. You can start with the definition of variance:
$$\text{var}\left(\frac{1}{h}\right) = E\left[\left(\frac{1}{h}\right)^2\right] - \left(E\left[\frac{1}{h}\right]\right)^2$$
where the expected values are calculated in the usual way using the integral definition. It looks like you are assuming that ##h## is uniformly distributed in the interval ##[2.7, 3.3]##, so you should be able to get a closed form answer without resorting to numerical approximation.
Likes 1 person
Creating a PDF for such variable
Thank you jbunniii for the quick response!
If I didn't know the value of h, how could I make a PDF for such variable? Wouldn't that require an equation of h to find such parameters? Or, if I do use those contraints from |2.7 , 3.3|, how would I go about making a PFD?
My advisor said I should first make a triangular distribution of the variable. To use a triangular distribution, I must know the aand b (where the value is zero) as well as the peak value, c.
There's no general answer to this - it depends on your specific problem. Where are the values of ##h## coming from? Do you have some measurement data? If so, you can try fitting a distribution to the data. [Sorry, I'm not an expert regarding how to do that, but I know there are statistical methods for doing this.]
Or maybe you just know that the value cannot be smaller than ##2.7## or larger than ##3.3##, so the distribution must be constrained to that interval. If you know nothing else, a uniform distribution in that interval may be reasonable. If you think the average ##3.0##is more likely than ##2.7## or ##3.3##, then a triangle or some other "peaked" distribution may be reasonable.
If you only know a mean and a variance for ##h## then a normal/gaussian assumption may be reasonable. It all depends on what you know about ##h##.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
