Calculating velcoity around a corner
  • Thread starter Thread starter mistry
The discussion focuses on calculating the maximum velocity for a buggy navigating 90-degree corners in a mechatronics project. Key factors include the coefficient of dynamic friction, centripetal force, and the vehicle's mass. Users suggest using the formula F=mv^2/r to determine velocity, while clarifying that the coefficient of friction differs from rolling resistance. The conversation emphasizes the importance of understanding these principles to optimize speed and braking on the track. Overall, accurate calculations are essential for effective control of the buggy's movement around corners.
mistry
Calculating velocity around a corner
Hi Everyone,
I am working on a mecatronics project to control a buggy around a track, which uses sensors to determine where on the track it is and has a separate, rear wheel motor controls.
I want to perform a theoretical calculation to determine the maximum velocity I can go round the 90 degree corners? I know the distance around the corner, and the aim is to use this information to work out the time. Does anyone know how to calculate this?
The overall aim is by knowing tha max velcoity on the corners, I can work out speed on the straights knowing how much braking is requried.
Thanks in advance!
Mistry
Hi Mistry,
First off I suggest read up a little about http://en.wikipedia.org/wiki/Circular_motion" , you will of course need to take into consideration a lot of factors about the vehicle such as the coefficient of dynamic friction between the tyres and your surface, air resistance and the centripetal force.
Hopefully this will give you a start for the logic.
F=mv^2/r m=mass v=speed r= radius of the turn .
make sure this does not over come the frictional force by F=(mu)(N)
mu= friction coefficient , which is the tangent of the angle at which the material starts to slide on the other material , and N= the normal force (mass)(g)
Hi, thank you for your replies.
Could I clarify one thing. This coefficient of friction, is this the same a rolling resistance or is that completely different?
Also using the information given, I need to work out the maximum speed I can go round. If I take the coefficient of friction to be between 0.6-0.85 (for rubber tyres on concrete) can I state the follwing
m/V^2/r = (mu)N
then rearrange to find V. Would this be correct
Thanks
yes then you would solve for v , I’m not quite sure about the rolling resistance.
But I think rolling resistance is different than the friction coefficient because the friction coefficient refers to sliding not rolling.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
