Calculating Voltage Drop for 200HP Motor at 480V
To calculate the voltage drop for a 200HP motor at 480V located 300 feet from the starter, the formula used is %VD(3phase) = [12(1.73)(300ft.)(240A)]/[(Circular mil) * (480V)] x100. The user correctly identifies that the full load current is 240A and uses 12 for copper. However, they are unsure about obtaining the circular mil value, which is necessary for the calculation. The circular mil can be found in the American Wire Gauge (AWG) chart, which is referenced for further assistance. Accurate voltage drop calculations are crucial for ensuring motor efficiency and performance.
vptran84
Hi,
I was wondering if anyone can help me figure out how much voltage drop is happening in this particular scenario.
Here is my work:
Given 200HP motor at 480V that is 300 ft. away from the starter.
I use 12 for copper, and with 200HP the Full Load Amp is 240A.
I have no idea where i can get the circular mil. Can someone please help me. I know that it's somewhere in the NEC.
thanks.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
