Calculating Weight of an Astronaut at Different Distances
  • Thread starter Thread starter nazz
    Astronaut Weight
The discussion focuses on calculating the weight of an astronaut at varying distances from the Earth's center. An astronaut weighing 1000N at the Earth's surface (radius 6500 km) will have a different weight at distances of 13000 km and 19500 km. The weight can be calculated using the formula W = M x g, where g is derived from the gravitational constant G and the mass of the Earth. An alternative method involves using the ratio of weights at different radii without needing the specific values of G and M.
  • Understanding of gravitational force and weight calculations
  • Familiarity with the formula for gravitational acceleration (g)
  • Knowledge of the Earth's mass and radius
  • Basic algebra for manipulating equations and ratios
  • Research the gravitational force formula and its applications in physics
  • Learn about the concept of gravitational acceleration at different distances
  • Explore the implications of weight changes in varying gravitational fields
  • Study the derivation of gravitational equations using ratios
Students in physics, aerospace engineers, and anyone interested in gravitational effects on weight at varying distances from celestial bodies.
nazz
An astronaut weighs 1000N at the surface of the Earth of radius 6500 km, what his weight will be at 13000 km and 19500km from the centre of the earth?
Do I have to calculate the new value of g at 13000 km using the following?
(G• Mearth) / (Rearth)2
Where:
G = 6.673 x 10-11 N m2/kg2
Mass of the Earth = (5.98 x 1024 kg)
New Re = 13000 km (converted to m)
Then W = M x g
Is there another way of solving it?
You can calculate the answer without knowing the values G and M (or GM). Try write up the equation for the weight W1 at radius R1 and the weight W2 at radius R2 using GM as you did above and then look at the ratio W1/W2.
Great answer Filip, thanks
  • · Replies 18 ·
